Question about Philips HDD1630 MP3 Player
Yellow triangle says to connect to pc, when i connect it it shows the picture of it being connected, however this does not solve the problem. and windows media player 11 doesnt recognize it. It has been recognized before but not now. Im sure the problem lies within the go gear.
  • Anonymous Nov 25, 2007
    same thing it says to connect to a pc but does nothing!!
  • shaz09 Dec 15, 2007
    same with me i have tried everything my player was working fine one moment then nothing the nent time i turned it on i also hear a ticking when i first switch on it goes away as soon as the triangle appears when i connect to my pc i get nothing
  • 476 Answers
Install and run Device Manager from the product CD.
Select the repair option, and follow the on-screen prompts.
NOTE: ALL FILES LOADED ON TO THE PLAYER WILL BE LOST.
If this doesn't work then it may be that the hard disk is faulty. There is an easy way to find out. The following procedure allows the player to connect to the PC as a removable drive. If the Pc reads the drive, then the drive is ok.
Connect the HDD1630 to the mains adaptor and the PC.
Before the computer has a chance to recognise the player, press "Power" and "Vol +" to reset the player.
As soon as the player resets (screen goes blank) press and hold "Vol -" until the PC recognises the player as a removable drive.
Try to access the player through "My Computer" as you would the main hard disk.
CLICKING HARD DISK is usually a sign of a problem with the hard disk. If this is the case it will have to be replaced.
The HDD16X0 series use a standard 6Gb Microdrive which are readily available, and much cheaper than the official Philips replacement. The new drive would need to be "Repaired" using the Philips Device Manager.
Posted on Feb 10, 2008
All I want to do is run the playstation thru my computer. Do I have to connect it to the internet to do that?
not internet but your home network.
i'm not sure you can use your playstation through your computer. but you can access your pictures, music, videos that is stored on your computer from your ps3. if you have the latest version of windows media player it makes it easier.
Using Windows Media Player 11 as the server
Open Windows Media Player 11
From the toolbar, select Library then Media Sharing
Check "Share my media"
On the PS3 - Under Video, Photos or Music, select "Scan for media server"
Go back to the PC, and you should see a pop up showing an unknown device trying to connect.
Allow the device, and everything should work.
Apr 28, 2010 | Sony Playstation 3 (PS3) Console
The pc is unable to detect the sansa disk
If you are using Windows XP: verify the following operating system requirements are met. - Windows XP SP2 or higher - Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. - Download the hotfix from http://support.microsoft.com/kb/939211. - Run the hotfix.
Refresh the driverd
1 - Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Apr 03, 2010 | SanDisk Sansa Clip MP3 Player
My sandisk is not detected
This may be caused by one of the following: 1. Minimum system requirements were not met. 2. Corrupted drivers. 3. Computer restrictions. 4. Power issue.
Try the following solutions:
For brand new player or first time connecting to a computer.
If you are using XP : verify the following operating system requirements are met. - Windows XP SP2 or higher - Windows Media Player 10 or higher
If you are using Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. - Download the hotfix from
--->> http://support.microsoft.com/kb/939211. <<----- - Run the hotfix. Solve your MP3 Player Connection Problem.
Mar 16, 2010 | SanDisk Sansa Clip MP3 Player
I am trying to put more songs onto my mp3 player. The songs show that they're on there on the computer, but when i unplug it the songs aren't shown on there. It says i have plenty of space, so that's not...
Hello.
Welcome To Fixya.
In order to have a succesful Transfer of songs from you computer to your mp3 player follow these Steps:
1/ Install:
  1. Insert the CD supplied with your product into the CD ROM drive of your PC.
  2. Follow the on-screen instructions to complete the installation of Philips Device Manager and Philips Media Converter. The Philips Media Converter converts video clips and JPEG pictures into suitable formats for the player.
2/ Connect and charge:
  1. Connect to PC:
    When you connect the player to the PC, it automatically charges.
  2. Connect the supplied USB cable to the mini USB port at the bottom of the player, the other end to your PC.
3/ Transfer:
Your player appears as a USB mass storage in Windows Explorer. You can organize files, transfer music and picture to your player during USB connection. Use Philips Media Converter to transfer video file. See Media Converter for details.
Transfer music:
  1. Click and highlight one or more songs to transfer between your player and your computer.
  2. Use drag and drop actions to complete your transfer.
Tip : To transfer music CDs to the player use software such as Musicmatch Jukebox or Windows Media Player, rip (convert) the songs on your music CD into MP3/WMA files. Copy the files into the digital audio player via Windows Explorer. Free versions of these programs can be downloaded from the internet.
Also you can Transfer Video:
The Philips Media Converter converts video clips and JPEG pictures into suitable formats for the player. You can install the software from the supplied CD.
Thank You For Using Fixya.
Good Luck.
Nov 06, 2009 | Philips SA3025/37 Flash MP3 Player
I cannot watch the Online TV on the internet.
Hi there.
Update Adobe flash player and try to connect again.
Get Adobe Flash player here >>>>>
http://get.adobe.com/flashplayer/
Also please be aware that not all channels seem to connect even though your steaming media player says that its ready, some channels play, others don't so its not always the media players at fault.
Good luck and thanks for choosing FixYa!!
Jun 05, 2009 | Acer Aspire 5100-5022 Notebook
Won't connect to windows media player after pc repair
put it in a PAMPER !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ********
Apr 17, 2009 | Audio Players & Recorders
No picture, only sound
Actually this is a problem of the video codec and you need o install some software that will solve your problem completely.
Download :
1) VLC Media Player :
http://www.videolan.org/vlc/download-windows.html
2) K-Lite Codec Pack :
http://www.free-codecs.com/K_lite_codec_pack_download.htm
Mar 09, 2009 | Acer Aspire One PC Notebook
How do i sync music
Go to yahoo and type sansa m230 and find a driver for it
Jan 21, 2009 | SanDisk Sansa m230 MP3 Player
Computer not detecting
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
THEN, do the "Repair" in the Philips Device Manager
Jun 01, 2008 | Philips HDD1630 MP3 Player
Rio 512 mp3 player
You need to connect the Rio to a PC and then use the Windows Explorer format disk feature to reformat the Forge's flash memory as a FAT32 partition.
Sep 08, 2007 | Rio Forge Sport Digital Media Player
Philips HDD1630 MP3 Player Logo
54 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
