Question about Brother XL-2230 Mechanical Sewing Machine
Uneven thread tension in same line of stitches
I've just bought a Brother XL2230 sewing machine (I'm a beginner, but have tried to make sure I've read the manual etc before setting it up). The problem is that I can't get the thread tension right - it's either too loose or too tight on the top, even in the same line of stitches. I am using Gutermann thread, which I thought was quite good and which I bought in the fabric shop, and the needle is the one that came with the machine so should be brand new. The fabric I'm using is like curtain fabric, so a bit heavier than cotton, but not as heave as canvas or denim.
Help! I'm really trying to keep enthusiastic about my new purchase, but it's driving me nuts!
  • cagsie Apr 11, 2008
    i have the same uneven tension. i can adjust the top tension but i cannot find any screw to adjust in or around the flat bobbin. can you help pls?
Can u showe me a visial on how to thread
Posted on Aug 02, 2008
Starting to sew basic stitch
You need to know how to thread the upper thread, wind thread onto a bobbin, and install the bobbin in the machine.
Be sure to lower the presser foot onto the fabric you are going to stitch.
Then press on the foot control pedal (like a gas pedal in a car). The harder you press, the faster it will stitch.
There are a lot of web sites and videos available. But, you should probably read the machine's manual.
How to Use your Sewing Machine for Beginners
How to Use Sewing Machine
How to Sew using sewing machine
Sewing 101 Guide for beginners like me The Dreamer
The Best Sewing Machines For Beginners She Likes to Sew
How to Use Sewing Machine Beginner Guide
Best Sewing Machines For Beginners Our TOP PICKS Sewing Made Simple
Oct 06, 2016 | Brother SE400 Computerized Sewing and...
My pfaff2044 started sewing uneven stitches. It can sew nice then next second leave a big stretch then sew normal again and then itll leave a bigger stretch it also wont blind stitch.
3 Common Sewing Machine Problems (and How to Fix Them)
Martha StewartSep 26, 2014 - We consulted Becky Hanson of Singer Sewing Company for her tips on ... The Problem: Stitches are coming out uneven or skipping entirely.
Basic Sewing Machine Troubleshooting - Sewing School
Mar 16, 2011 - The thread breaks, my needle bends, or skipped stitches - UGH! Don't get ... Problem: My stitches are uneven and sometimes skipping!
My stitches are coming out uneven -
What to do if the stitches from your sewing machine are coming out uneven. Sewingmachine troubleshooting guide.
Dec 12, 2015 | Sewing Machines
Why is the bobbin thread looping and catching on my sewing machine? The stitches are uneven, too.
Hi Sylvia,
Your problem is an un-matched tension of the threads. You mentioned doing an adjustment recently. That is the problem area.
If your bobbin thread develops loops on the top side of the fabric, you need to tighten the bobbin tension.
There is no easy method for this and you will have to do it slowly -
tighten, test, re-tighten, test.... until you get a near perfect stitch.
I haven't come across a portable device specifically designed to set thread tensions.
Oct 08, 2014 | Dual Sew 3400 Mechanical Sewing Machine
I can't form any stitch on my brother 3d - they are all loose and long and uneven. Do you know how to fix this please?
try changing the needle
try adjusting the top thread tension to 3 or 4
rethread the machine top & bobbin
make sure the bobbin is inserted correctly
& also wound correctly
Aug 05, 2012 | Brother Sewing Machines
Thread tension
try changing the needle first--make sure the needle is the correct one for the fabric being sewed.
if you've adjusted the top tension & the bottom stitch still looks the same
it's possible that the top tension dial is needing to be checked to see if it's
working correctly
Apr 17, 2012 | Brother CE4000 Computerized Sewing Machine
The stitches on my brother 3125 sewing machines are loose. On the top and bottom. Ive tried to redo my stitching and nothing has worked . Please help !!!
Make sure presser foot UP position. Rethread making sure thread is taut so it can locate tension slots. Rethread needle making sure its up in the needle bar shaft--flat side BACK--thread goes through needle eye front to back. Tension: 4 Jimmy
Apr 04, 2012 | Brother LX3125 Sewing Machine
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
May 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother XL2230 Elastic Overlock function not working properly
First of all check your needle size and utility, for the tension machine it must be the same on top and bottom example pull the top thread and the lower thread they must be the same.
When sticthing the elastic you must devide the amount of elastic versus the fabric : dise the amount before stiching
Hope this will help
Good day
Feb 16, 2009 | Brother XL-2230 Mechanical Sewing Machine
Uneven stitching from bobbin
Hi there!
Well you're right it's a tension problem.
Sounds like there is little or no tension on the top thread.
You probably have thread stuck in your tension discs. If so, set the tension at zero, open the discs with a small screw driver and blow between them. Sometimes you have to dig it out with tweezers.
Then reset clockwise untill you can feel the tension on the thread when you pull through it. It should be about the same as pulling a mug of tee along a table. (not specific I know - but you get the idea - and I love the tea!)
Hope this helps you.
Jun 17, 2008 | Brother Sewing Machines
Ls1217 Brother
It sounds like you may have uneven tension between the bobbin thread and the upper thread. You can adjust the tension via a screw on the bobbin case. Turn it clockwise to tighten the bobbin thread tension and counter clockwise to reduce it. It's also worth remembering to check the tension on the presser foot for the material you are using. Check also that the shuttle race is clear of lint etc. Hope this helps
Jul 02, 2007 | Brother LS-1217 Mechanical Sewing Machine
Brother XL-2230 Mechanical Sewing Machine Logo
211 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
