Question about GE Nautilus 24" Built-in Dishwasher
My dishwasher will not drain, I have removed the screens, tried to run a wire through, and put drain cleaner in overnight but nothing works,,,, Do I need a drain pump? Thanks, Bonnie
How can I drain my dishwasher?
Posted on Jul 18, 2009
Grohe drain stopper installation
Try cleaning drain with a length of wire. Strip insulation back about an inch. Turn exposed wire back to form a hook and put down drain and spin, then remove from drain, repeat until hook comes out fairly
clean. Then put drain cleaner down drain, follow instructions with drain cleaner. This should remove gunk that is preventing stopper from working correctly.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Jan 20, 2014 | Plumbing
Hello the bottom of my dishwasher keeps filling up with water. How can i fix that??
The problem may be in one of several places, here's a list of things to try, starting with the easiest and progressing to more difficult:
1. Run your hand around the bottom of the pool in the dishwasher looking for paper or cellophane that may be covering the screen of the drain. 2. Disconnect the drain hose from under the sink (get a bucket and rags) looking for a clog at that point of connection. Run the dishwasher drain cycle while you have this hose pointed into a bucket - if nothing comes out, the problem is between points 1 and 2. 3. Partially remove the dishwasher so you can get to the drain hose where it connects to the dishwasher. Temporarily put another drain hose on it, with the other end in a bucket. Run the drain cycle of the dishwasher. If it comes gushing out, the drain hose is clogged. If it still won't drain, your will need some disassembly of the drain & pump. good luck, Al K
Dec 21, 2010 | Mx Commercial Line Drano Max Clog Remover
Our dishwasher will not drian out all the way. I cleaned out the screen and sump and it still does not drain out all the way. I also ran the unit and waited for the drain cycle and it seemed to flow...
hi Richardcr1.
After having examined many dishwashers that were replaced because they wouldn't drain, the largest percentage of them were simply because of a clogged drain hose or pump strainer. Too many people seem to think that the dishwasher is first cousin to a garbage disposal. It is not.30 Apr 2010
SOLVED: Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/Answers/View/.../Does+not+drain+the+water+at+the+end+of+cycl...
How do I fix my dishwasher that will not drain?Check for a clog:Make sure the kitchen sink drain is not clogged.If a disposer is installed, run the disposer to clear the drain system. Do not put hands into the garbage disposer. ...If an air gap is installed, remove the cap and remove any debris. ...Do not use drain cleaner in the dishwasher.Dishwasher Does Not Drain - Products - GE Appliancesproducts.geappliances.com/appliance/gea-support-search-content?contentId=16240Search for: How do I fix my dishwasher that will not drain?
Nov 29, 2017 | General Electric Dishwashers
Too much sink water causes flooding from dishwasher.
If you let it sit with vinegar and it worked after for a while that tells me it may be plugged up with grease. Might be worth while trying to clean it out with Drain O a drain cleaner. Make sure its washed clean after. Grease and dirt builds up after a while in all machines. If vinegar works might be worth cleaning more often.
Mar 14, 2017 | Maytag PDB4600 Built-in Dishwasher
I have grit on my dishes after the wash cycle completes, jet dry seems to be working? Dishwasher is draining.
use only cascade complete cleaner, clean unit remove basket motor cover chopper cover clean and vac out trash washer all screens increase water temp. to 130 degrees if no children in home if children in home not over 125 degrees temp. monthly run dishwasher cleaner product through waser cost around 10 $ at lowes
Feb 05, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
It isn't draining. There is dirty water sitting in the bottom of it. Tried to see if anything was blocking the drain but couldn't find anything.
Check the entire length of the drain hose from the washer bottom to the connection at the sink drain for kinks--you may need to pull the machine out of the cabinet part way to check. Make sure the hose passes over a point higher than the drain connection at the sink. If you have access to a wet/dry shop vacuum, remove the sink end and **** the water out. If nothing comes out, then there is an obstruction somewhere. Use the vacuum to **** the drain opening inside the washer.
Sep 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher didn't drain - totally non-responsive panel
Hello , that wire is only a ground wire, it should be hooked up to the frame . The draining problem is the water pump not being powerful enough anymore to pull the water out. I think there are rebuild kits , but its not expensive to replace either. It would be a great saturday am project! Thanks , Quinn
Aug 21, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Maytag MDB9600A does not drain well & is noisy
try using a dishwasher cleaner, u can find it at walmart or your local supermarket. I found "dishwasher magic" is Wia good brand. U could also try several packets of lemon koolaid mix, the stuff in the small packets without the sugar in it. Run a complete cycle with the hottest water possible, and no other dishes in the washer. Make sure to read the directions on the bottle of dishwasher magic. hopefully these cleaners will clear out any deposits that are blocking your system. U might need two run a second cycle to clear out everything. If this does not work, and your washer still does not drain properly, your pump may be malfunctioning. Remember to make sure u load your washer correctly too. Which ever rack u put your plates on, make sure they are all vertical, and everything else on that rack should be loaded the same way. this will allow water to easily shoot thru to the second rack of your washer. u can load your second rack however, just make sure nothing will be hitting the water jet blade and prevent it from rotating.
Feb 15, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dishwasher not draining (neff slimline intergrated)
I had this problem and eventually after trying everything short of pulling the dishwasher out and checking the hoses I tried Finish Dishwasher Cleaner. Much to my surprise, IT WORKED.
Dec 30, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Broken dishwahser
Check to see if there is a waste basin at the bottom of your dishwasher. Some models have them and they require regular maintenance / cleaning every 6 months or so. If one does not exist, try to purchase one of the JetDry Dishwasher cleaner and set your dishwasher to run at its hottest (usually "pots and pans" or "extra hot") for about 2 cycles. That should clean the drain of the large food particles that have accumulated in the dishwasher drainage. Should the above not provide satisfactory results, you may want to try a VERY SMALL AMOUNT of drain cleaner in the middle of an empty cycle to try and remove the debris. (CAUTION: too much drain cleaner will damage the waste bin if not rinsed properly and render your dishwasher useless..please only do this at your own risk)
Jul 24, 2007 | Whirlpool 24 in. ADG6340 Built-in...
GE Nautilus 24" Built-in Dishwasher Logo
957 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
