Question about Apple iPod classic MP3 Player
Ipod has frozen, how do i re-set it? - Apple iPod classic MP3 Player
    Problem Solver:
  • 3 Answers
Hold down the middle and play/pause button at the same time for 10 seconds and it should automatically reset.
Posted on Jul 16, 2009
My ipod 4gb wont turn of its frozen?
Hi
Please press the center and stop/pause button until your ipod resets itself or until apple logo appears. Also try to connect your ipod with your computer and restore the ipod settings with itunes.
Please accept the solution and revert for further assistance.
Thanks
Rylee
Jul 07, 2009 | Apple iPod nano
Tip
The battery of my iPod is not charging
<p>When you buy an iPod, the device comes with cables that connect the charging device to the computer. When the iPod battery is low, you can recharge by plugging into your desktop or laptop. But sometimes, when you connect your iPod to your computer, the battery charger. According to Apple's site, some problems may prevent your iPod from charging properly. <br /> <p><br /> <p>1. Connect your iPod USB charging cable only one USB port on the computer itself. External port devices, such as a USB hub, do not provide enough power to recharge your iPod. <br /> <p><br /> <p>2. Connect the iPod firewire charging only one firewire port on your computer. Like USB, Firewire ports are not enough of a load to the battery of your iPod. <br /> <p><br /> <p>3. Disconnect the computer from sleep when the computer set to sleep after a certain time. An iPod can only load on a computer that is connected and not in sleep mode. To enable sleep mode on most computers, you can move the mouse or press the power button once. Hold the power button, which usually turns off the computer. <br /> <p><br /> <p>4. Turn the iPod off and on when the unit is frozen. A frozen iPod is not charging. If the unit is still frozen when you turn it on again, restart the iPod by pressing the "Hold" switch to "On" and then back to "Off" and press and hold a "Menu" and "Select" buttons simultaneously or " Start "and" Menu "button. Hold the buttons until the Apple logo appears on the screen. <br /> <p><br /> <p>5. Set the system up-to-iPod charger so that when using a Windows 2000 computer. In preparation for the system to load the iPod device to the unit with the charging cable, launch iTunes and "iPod" in the left pane to "Settings" tab to go, check the box next to "Enable Disk use", and click the "Apply" button. Once the configuration is in place, the iPod will charge as normal. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How Do I program my iPod Touch
<p>Completely reprogram your iPod touch by performing a "Restore". Do not let the name fool you, Apple's restore feature restores the original factory settings, so the iPod unit is clean, except for the operating system. Access to restore utility in iTunes. If your iPod is frozen or stopped working, first manually reset, and then restore in iTunes. <br /> <p><br /> <p>1. Hold the "Sleep / Wake" button and the "Home" button at the same time as your iPod is frozen or unresponsive. Holding the button until the display converts the iPod Touch in recovery mode. <br /> <p><br /> <p>2. Press the "Home" with one hand while you connect your iPod to your computer with disabilities with the other. ITunes will ask you to restore your iPod in recovery mode. <br /> <p><br /> <p>3. Click "OK" to start the recovery process. When iTunes is finished, your iPod Touch is completely reset, ***** except for the original operating system, and ready to reload with new data. <br /> <p><br /> <p>4. Connect the iPod Touch directly to your computer as usual, a restore point to start, without going into recovery mode. Open iTunes if it does not open automatically. <br /> <p><br /> <p>5. Click the name of your iPod under Devices in the left pane of the iTunes window. "Summary" tab open. <br /> <p><br /> <p>6. Look for the "Restore" button to the center of the window. Click this button. <br /> <p><br /> <p>7. Confirm that you want the iPod Touch to its original factory settings. This is your last chance to change his mind. <br /> <p><br /> <p>8. Wait until iTunes has finished. The iPod is restored to its original factory settings. <br />
on Aug 05, 2011 | Computers & Internet
Frozen ipod
Hey i scored you these instructions on how to reset your frozen ipod. Hope its hella useful. Good luck :)
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
If the iPod is connected to a computer and displays any of the following messages you should eject the iPod from within iTunes instead of resetting it:
Connected. Eject before disconnecting Sync in Progress. Please wait... Do not disconnect If your iPod is frozen or won't turn on, the steps to reset it vary by model. You can easily tell which iPod model you have if you're not sure.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Apr 23, 2009 | Apple iPod MA446LL/A MP3 Player
Frozen ipod/4bg
Hi! Wait for the iPod to discharge and it will automatically turn off when its battery gets discharged or press the middle button and play button simultaneously. It will reset the ipod
Dec 27, 2008 | Apple iPod nano
Apple iPod is frozen
Well...Hmmm?First did you lay it upside down on a towel so the water could drain? And you could plug it in to your computer,(When it's dry),and go to itunes then click on your ipod and go to settings and click restore. Hope I helped! :D
Jul 23, 2008 | Apple IPod nano Second Generation MP3...
IPod Nano 3rd Gen. Frozen on main screen. will restart (menu+select) but goes back to being frozen on main screen help asap pleaase
yes it can if it will load in to my computer? look for divce g right click and format it you will lose every thing but it should solve your problem when done use itunes to restore settings ? let me no how you get on
Jan 24, 2008 | Apple iPod nano 3rd Generation
Error screen and frozen screen
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Jan 08, 2008 | Apple Ipod Nano Second Gen. Green (4 GB)...
Apple iPod classic MP3 Player Logo
67 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
