Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Pressure loss wil only produce 20lbs of pressure reguardles of adjustment
    Brigadier General:
  • 4,088 Answers
Does the tank have a serious air leak? If it looks like it is centered around the compressor, remove the cylinder head. Check and clean the intake and outlet valves. Check the safety valve on the tank that it is not leaking. Listen everywhere for a hiss while it is running. Make sure the belt isn't slipping.
Posted on Jul 16, 2009
Belt diagram for alternator belt 03 kia
your Kia dealership can print you a diagram.
Feb 20, 2014 | 2003 Kia Spectra
Oil pressure is jumping from 20lbs to 0lbs,truck almost dies then the oil pressure jumps back up to 30lbs then back to 10lbs ,
To start, take the vehicle to a dealer and ask them to screw an oil pressure gauge into the block hole and check your oil pressure whilst idling and while driving it.
I have a 1993 and it does the same thing, but the problem is only the gauge itself.
If it is actually having such oil pressure fluctuations, you may have a defective pump, a clogged pump filter screen, or a clogged oil filter.
God bless your efforts.
May 18, 2017 | 1992 GMC Sierra
Myers pump will not pump up past 20lbs on an artisian well system.
Hi susan_nash
Be sure your pump is not "air bound"...meaning that air is in the pump not causing it to prime properly and that will cause it not to build up pressure and keep running.
Prime your pump properly and that should solve your problem
Please rate me
Bud
Sep 26, 2012 | feMyers Fe Myers HJ75S HJ Series Shallow...
Adjusted pressure switch and pump still does not go up past 20lbs
Forgot to mention, pressure gauges fail all the time....
Sep 26, 2012 | Plumbing
My suburban seems to burn way to rich to the point you can smell it in the exhaust. and runs rough. is there an ajustment on it like to older carbs had? GREG
No adjustment. If the engine has a throttle body injector, the injector could be stuck open. If the fuel pressure regulator has lost control, the pressure could be too high forcing excess fuel into the engine. The O2 sensor may have failed causing loss of fuel mixture control. Take the vehicle to Autozone or similar business for a free scan of the computer--if any codes are produced, they are clues to your problems. Don't start shotgunning parts to see if it will fix things. Hope this helps!
Jan 17, 2011 | Chevrolet Suburban 1500 Cars & Trucks
Compressor tamk pressure
That small piece of rubber came from the compressor pump, more than likely you have a broken valve or blown head gasket in the pump, that is why it will not build pressure.
Feb 02, 2010 | Craftsman Air Tools & Compressors
Oil pressur drops a little when coming to a stop
This is natural as long as it does not drop too low. No less than 20lbs/in. Oil pressure increases with RPM's. That's why we have the guages! Hope this helps your concern.
Nov 24, 2009 | 2000 Chevrolet Blazer
Compressor will run but wont build more than 20lbs of air
LOOK FOR AIR LEAKS-ALSO HIGH PRESSURE CUTOFF SWITCH MAY NEED
ADJUSTMENT.
Jun 20, 2009 | Air Tools & Compressors
Adjusting air flow on gas kitchen stove burners?
Proper air velocity over the burner is critical on a direct fired gas unit. If the air velocity is not within
specifications, the unit will not operate efficiently, can produce excess carbon monoxide (CO) or other gases, and may have sporadic shutdowns. Proper air velocity is determined by measuring the static pressure drop across the burner.
To measure the static pressure drop, the fan should be running and be discharging 70° air. Using an incline manometer or equivalent, insert one sensor into the entering air access opening (plugged test port) and the other on the downstream side, through the view port (see page 12 for locations). The proper static pressure reading should be from .625 in. to .675 in.
If this reading is higher or lower and the air quantity (cfm) delivered to the building is acceptable, then the burner baffles will need to be adjusted (see diagram).
Open the burner access door. Using a wrench loosen the 4 screws to adjust the baffles. To increase the static pressure loss, decrease the opening size and to decrease the loss, increase the opening size. The top and bottom baffles should be of equal distance from the burner. Tighten the baffle fasteners, replace the door, turn unit on, and recheck the loss. This process may need to be repeated
until the proper pressure reading is attained.
This adjustment will change the air quantity delivered by the unit and therefore should be rechecked.
Sep 05, 2008 | Maytag Kitchen Ranges
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
174 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
