Question about Whirlpool Duet GHW9150P Front Load Washer
Where can I find model number on my duet washer ?
  • 5,911 Answers
Open the door and look at the name plate data along the front panel opening. You should see the model number, along with the serial number.
Posted on Jul 16, 2009
5 Suggested Answers
  • 7 Answers
SOURCE: where is the model number found on duet?
When you open the door it is on the frame
Posted on May 05, 2009
  • 4090 Answers
SOURCE: give me a sample whirlpool duet stwasher and dryer serial numbers
What? we dont supply serial numbers sorry! go to whirlpool
Posted on Aug 30, 2009
jumptrout51
  • 3361 Answers
SOURCE: older whirlpool duet washer has error F11
F11 is a serial communication error between the central control unit and the motor control unit.
Unplug the machine and open the panels.
Unplug and re-plug all wire connectors from the ccu to the mcu.
Inspect all wires and harnesses for a bad wire.
Could be bad components; ccu or mcu or motor
Posted on Feb 23, 2009
blueextc3221
  • 15935 Answers
SOURCE: WHIRLPOOL DUET WASHER MODEL NUMBER GHW9400PW4
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
How to replace circuit board in whirlpool duet washer
all work on washers and dryers is managed by removing the back panel FIRST.
www.appliancerepair.com - enter your model number and watch the videos provided at that website. GREAT WEBSITE BTW
Feb 12, 2015 | Whirlpool Duet GHW9150P Front Load Washer
I need the operating manual "How to" for the Whirlpool duet washer and dryer.... thank you....
Hi and welcome to FixYa, I am Kelly.
If you would please.... find your model number(s) as there are at least 3 versions of the whirlpool duet. Then you can go to this site:
http://www.whirlpool.com/custserv/index.jsp
and enter your model numbers one at a time where it says Manuals & Literature to down load the manuals.
Thanks for choosing FixYa,
Kelly
May 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light on my front load washer,I cant get it to turn off. washer wont work now
If it is a Duet model there press the button at 5 o'clock for more than 3 seconds to unlock the control panel. If it is NOT a Duet model... we need you model number ot help you as there are different methods of unlocking the controls depending upon the manufacturer and model. So plese provide a model number if possible... or at least a brand and what you think it is. Thanks.
Kelly
Mar 18, 2011 | Washing Machines
Whirlpool washer duet is flashing after adding garmet. Will not return to washing
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Jul 29, 2010 | Whirlpool GHW9300 Duet Washer
Give me a sample whirlpool duet stwasher and dryer serial numbers
Aug 30, 2009 | Washing Machines
Older whirlpool duet washer has error F11
Feb 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FRONT BELLOWS
I have a whirlpool duet washer i can't retrieve the model number because the door is locked but the dryer which is the match to the washer is model number GEW9200LW. My question is that when I hit the control button then start, a muttled beep will sound not allowing the door to open. I get an error message of DL then it flashes to F? Any help?
May 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
5,180 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
