Question about Hard Drives
Laptop computer problem
Hi I have a IBM Thinkpad 390x Laptop which has broken haed disk drive and I would like to upgrade to a larger one is this possible and how do i know how big i can go that will fit both the bay and compatible with BIOS
  • 150 Answers
Re: laptop computer problem
Here is a link that will give you all the updated bios and drivers. In this there is a link for Bios Update (Diskette), you need to follow the instructions there. The BIOS upgrade is usually these steps.
  1. Download the BIOS update to another computer
  2. Run the BIOS file you downloaded
  3. This will ask you to create a boot disk for the other machine, have a diskette ready that is compatible with your machine
  4. Insert the diskette into your computer and boot it up to the diskette.
  5. The diskette will then take over and ask you to not reboot or touch the screen as the BIOS is updated.
  6. The system will reboot, and your BIOS will be up to date.
The following links help you to know what drivers for what operating systems and components are required.
As for new parts for your computer, you can find them here. This link tells you how to update the HDD and the 9.5 mm HDDs are availble. There are 30GB or 40GB hdd.
It's possible to go higher, like night71 describes, but if you want to keep it simple, this might help.
Posted on Dec 01, 2007
  • 327 Answers
Sorry to but in with this one. I have a 300GB drive and works great with Windows XP. I had to format it on a MAC so Windows recognized the large size. Sounds funny but if you can find a MAC, then your problem is solved.
Posted on Nov 18, 2007
  • 317 Answers
Assuming you have Windows XP, the hard drive limit would be 137GB. You can go higher than that, but you'd probably have to upgrade your motherboard and do some registry modifications.
0 characters
3 Points
My thinkpad r61e's hard drive was erased how do i get back in it
Was it formatted ,Deleted or just Crashed ???...
The Thinkpad line of laptops, owned and produced by Lenovo, is a series of portable computers. The Thinkpad line was first introduced by IBM in 1992, but has been manufactured under the Lenovo brand since 2005.
At the time it was introduced, the Thinkpad was one of the few affordable, yet high-quality laptops on the market.
Laptops were, at that stage, vastly more expensive than desktops.
The Thinkpad line runs the Windows operating system.
Windows, while generally efficient, has the capability to suffer hard drive crashes.
Fortunately, Thinkpad laptops carry Lenovo's Rescue and Recovery program.
This program can help in crash situations.
Shut down your computer.
Start up your computer.
Watch for the Windows prompt that asks you to press your computer's ThinkVantage button.
Press the ThinkVantage button when prompted, then release it.
Rescue and Recovery will open.
Follow the wizard's instructions
Check the recovery link listed in Link Below (using another computer) for more info if you encounter any difficulties during the process.
There are also Data Recovery programs that might be very helpful to recover your important information.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
Aug 13, 2013 | Lenovo 160GB FDE 5400rpm SATA for ThinkPad...
Replace laptop hard drive or replace laptop. Current 80 GB Toshiba?
It depends on what you run on this laptop ..but if you only run windows xp do not need a larger hard drive ..and if you only need space to store data can just get a usb external hard drive and avoid the trouble ..The hard drive will be fully usable in other computers too and this is the advantage if you will upgrade in the future to another one with high performances ..
If you have at least a 1.6 cpu on it ..and 1 G of ram memory and you think you may run windows 7 can upgrade it to a larger hard disk ..but remember that this one runs on ata ..and I'm not sure it worth the trouble .
If you have at least 1 G of ram memory on it you can run windows 7 with this hard disk too ..but you will probably have to change the partitions configurations and make C drive at least 40 G so to have space to run it proper..
let me know if you have other thoughts related with this matter ..and i will answer it ..Please rate my answer to help my activity here ..thank you ..!
Dec 19, 2011 | Toshiba MK8025GAS 80 GB Hard Drive
What kind of hard drive do I need for a Nobilis ACY13 laptop?
Any laptop manufactured within the last few years will have two characteristics:
1. a 2.5-inch format (not the larger 3.5-inch format as used in "desktop" computers)
2. a SATA (Serial ATA) interface, not the much-older IDE/PATA interface.
Hint: take your computer to a computer-store; if they are "customer-service-oriented",
they will sell you a compatible disk-drive, *AND* remove the old disk-drive, *AND* connect the new disk-drive, at no additional cost, other than the cost of the new disk-drive.
May 21, 2011 | Hard Drives
Hi, I have an error message on my notebook laptop reading: 'windows detected a hard drive problem (repair or replace disk). Disk Failure Name: ST98823AS ATA, Device Volume C:\. How do I go about repairing...
Leila, repairing a hard drive or replavcing it in a laptop is difficult due the the number of screws and bits and pices one has to remove to get to it. I suggest you take it to a computer specialist that deals with the brand of laptop near you New disk varies depending on size but average about$160.00 and min 2 hrs labor @ $90 and hour. The decision is is it cheaper to upgrade than repair?
Please rate my help++++Thanks for using FIXYA
Jul 31, 2010 | Seagate Momentus 5400.2 ST98823AS...
How do I change out the harddrive
look where you plug in your headphone/mic jacks on the bottom of the laptop there should be at least 1 screw holding a plastic cover over these audio parts, unscrew that and pull out the hard drive attached
Oct 06, 2008 | IBM Axiom 80GB HDD ThinkPad 755, 750, 360,...
Portable Harddrive - Works on Newish Lappy, not on old Thinkpad
Time to install an XP driver for your PCMCIA card.
Sep 15, 2008 | Hard Drives
Hard Drive
Hi Patrick,
ATA and SATA are basically the same. The SATA drives won't work with the machines that are designed for IDE, so you're stuck with IDE on the I-series. Check out for buying hard drives. You'll be able to get them for half the price Bestbuy sells them for.
I'm not sure what's involved in getting the fingerprint device to work, if it's just a driver or a combination of driver and software. I've never worked with or had one before. I'll look into it. Have you read any of the forums at IBM's support site on this?
Aug 07, 2008 | Western Digital (WD1000VE) 100 GB Hard...
Hard disk upgrade for Gateway mx7118
check Gateway's support for possible help here. Most laptops can be upgraded substantially, RAM or Hard drive.
Gateway's site- I didn't see any BIOS upgrades.
Perhaps someone on this site has made such an upgrade and can give you a definitive answer.
Jun 18, 2008 | Hard Drives
Hard Drives Logo
359 people viewed this question
Top Hard Drives Experts
Brian Sullivan
Brian Sullivan
Are you a Hard Drive Expert? Answer questions, earn points and help others
