Question about Canon PIXMA MP830 All-In-One InkJet Printer
Toner is oozeing out. Changed toners, and also did a "Bottom Plate Cleaning". Did not ooze while cleaning, but did shortly thereafter. Any suggestions?
    President:
  • 2,306 Answers
You need a good cleaning, a new ink absorber and Canon now has a mylar strip that needs to be installed under the printer so this won't happen again. Best done in the shop..
Posted on Jul 24, 2009
Ricoh aficio mp 1600 add toner problem ?
If its not adding toner there could be 4 possible causes, 1.make sure all the covers are closed, if they are not then the machine will not "run" to add toner. 2.Did you check to make sure there is enough toner in the toner bottle. 3. when the machine starts running/adding toner, can you feel a vibration or hear noise like gears grinding/slipping, if so, call a technician to replace drum/dev gears.4. when you open the toner tray/harper/hopper, at the bottom there is a flat silver sliding plate, when you slide it open, is there toner falling oout of that hole, if not, ask a technician to strip and clean the toner tray/ harper/ hopper.
May 01, 2014 | Ricoh Aficio Mp-1600 Copier
Sharp Al1655cs copier black smudge down center of page about as wide as a pencil
Hi
Sounds like a fusing error . If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit).
Also clean the copier's paper rollers. Marks on copies will occasionally be the result of a dirty paper-rolling mechanism. Simply access these rollers (your photocopier will likely have a plaque or series of signs indicating the locations of these areas) and wipe them off.
Clean the copier bed's glass plate. One of the most common causes of blemishes in photocopies is a dirty glass plate. In some cases a permanent mark, such as a scratch, will be present on the plate, showing up in every copy as a dark line or spot. However, most problems attributed to the glass plate can be fixed by wiping the plate with a soft towel and common household glass cleaner.
Clear any excess toner that has spilled or overflowed in the toner cartridge chamber. Excess toner will almost always result in blemishes on your copies. The most effective means of cleanup is to remove the toner cartridge and set it aside, thoroughly cleaning up any spilled toner in the compartment before putting the cartridge back in place.
Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy. Most photocopiers will automatically indicate the need to replace an empty or low toner cartridge; while the toner is low, these models will permit continued copying. Consult your photocopier's instruction manual or key to warning lights and indicators for how to tell if the toner is low or empty.
Aug 03, 2011 | Office Equipment & Supplies
Error code 19
E019
Indicates that the waste toner case is full.
Thereafter, if the waste toner case is not replaced after making a total of about 2000 prints
(A4/LTR), the machine will indicate 'E019' on the control panel; the error code can be reset
by replacing the waste toner case and then turning off and then on the power switch.
If the waste toner case is not set, the light-blocking plate will block the light between the
photosensors, causing the Waste Toner Case Full message to appear.
Feb 04, 2011 | Canon imageRUNNER 2200
Ghost image towards bottom of page. Does this indicate my drum should be changed out?
Hey
if its a standard black toner printer your drum will need changing its probably not the photo drum itself but the cleaning wire that is attached to the drum unit is dirty...but there is no way to fix this but to replace the drum module..
If its a color toner it's the same thing the "drum" needs to be changed but in a color toner printer it's actually called a transfer film.
hope this helps,ben
Jan 04, 2011 | Dell 3010cn Laser Printer
Samsung CLP-315W color problem. The toners are all about 50% but the pictures are coming out red and very little yellow. I have cleaned the inside and emptied the extra toner.
Here's something you can try. There was a model of Samsung color laser that had an issue with the cleaning blades in the toner cartridge or toner transfer roller assemblies.
There are two types. I believe yours uses a "classic" toner cartridge (rectangular with a toner transfer roller on one side and a metal plate almost touching the toner transfer roller).
The metal plate can be removed and the edges cleaned. When you remove it, inspect the edges. One edge is used to clean the excess toner from the roller as it turns. Very gently clean the edges with a soft cloth and some windex or alcohol. Reassemble and test.
The other type uses round drum shaped toner cartridges. These printers have a toner transfer assembly for each color inside the printer on the main image transfer unit. These toner transfer assemblies will also have metal plates on them which can be cleaned. They must first be removed from the toner transfer assembly, you may need a jewelers screwdriver to remove them.
Be careful, the cleaning edges of these metal plates can be very sharp.
Oct 07, 2010 | Samsung CLP-315W Laser Color Printer
I had a Ricoh Aficio 2035 and i encountered Frequent toner spilling. almost everyday i clean the toner disposal tank located under the transfer charge belt. what part or remedy should i do? i try to lower...
Clean the PCU unit components:OPC drum,cleaning blade,charge roller.
Clean in the developer unit the development roller,and the entrance seal plate.
Raise the toner bottle holder lever,push the lever to the side and then pull the toner bottle holder out and clean this unit to use a vacuum cleaner.
Clean the transfer belt cleaning blade and the rollers.
Nov 22, 2009 | Ricoh Aficio 2035 Copier
Epson C1100 K toner low, right hand side can't print
Well if the margins are not the issue, then I would change it.
But before that, try taking a cotton swab, and cleaning the "k toner", the bottom part where the ink comes out. This way before investing more money into your printer, this 'k toner' might just needed a bit of cleaning.
Good luck
Sep 10, 2009 | Epson Aculaser C1100 Printer
Dark bands on bottom of all printed pages from rollers?
When you changed the toner did you clean the printer? There should have been instructions that detail cleaning the charging wire and charging grid.
If you already threw those out please let me know and I can assist you with the cleaning. If the cleaning does not help than it could be a drum issue and I would recommend calling your servicing dealership.
Henry
Jun 23, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
old marine
old marine
