Question about Panasonic PT-47WX49 47" Rear Projection Television
Need boards worked, is there a place to send the two boards?
Looking to send my two current boars out, or piurchase used boards that work.
  • Panasonic Master
  • 8,617 Answers
Bad gun boards trying to trouble shoot big buck pro gun boards
after open the gun check also the coil or coils in the target if it is open your gun will no work even if the switch's work properly
Nov 27, 2013 | Arcade Raw Thrills Big Buck Hunter Pro...
Wire feed problem with snap-on mig welder
There are two wires comming from the circuit board to the wire feed motor. You can try running the motor directly from a 12v battery or two for 24 volts. You might want to look at the name plate on the motor to check the normal DC current it draws. If you do not have an ammeter, you could use a fuse close to or just under the normal current. If it runs and draws too much current, then you know you have motor problems.
If it runs well and draws a fraction of normal current,you know the motor is good. Before you condem the circuit board, check that it is receiving the correct input voltage. If the welder is dual voltage,then somebodys mistake making voltage change could send 240 v to the board that is meant to receive 120v.
Hope this helps, Robert
Aug 21, 2012 | Hobart Handler 140 Mig Welder
My kids got Tony Hawk shred for wii on christmas and we have tried to calibrate the boars several hours and it doesn´t work. We have tried to change batteries and so on. The board is placed with a...
I had the same problem today and I know your frustration. I read alot of "solutions" but they were more like a series of coincidences. Understand that most USB devices are plug and play so the firmware and/or software have to be installed prior to activating the device. Here are the steps I preformed to solve the hardware problem.
1) insert the game disc and use your standard controller to begin the game.
2) when you see the message about lost communication insert the USB dongle and then power up the Board.
3) then follow the onscreen commands as far as syncing the board.
No need to dim the lights, put in old batteries, or move the furniture out of the room. Hope this helps.
Dec 25, 2010 | Video Game Consoles & Games
Key boar are not working volage checked key board
format os install once try or change the key board because if vairus is there it will happen so
Mar 17, 2010 | Computers & Internet
Dvd/vcr player under warranty. dvd drawer will not open and therefore vcr not working. Model no. v6700 piurchase from myer.
Get in touch with the dealer and report complaint. In fat the company should replace it OR ask yyou to send it to authorised dealer for repairs
Nov 23, 2009 | Televison & Video
How do i advance the defrost timer
You don't have a defrost timer, you have a mother board probably on the back of the unit. It determines when to defrost based on the usuage of the unit.
you can force defrost with a jumper from J11 to J9, then monitor current. Assuming fridge is freezing , this should supply current to defrost coils. If not working, you have a bad heater or defrost thermostat. If this works, you have a bad mother boar
Sep 04, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
SHUTTLE MV42N MOTHERBOARD DRIVER
can any body give me a driver for my shuttle mv42 mother bord coz i dont have any sounds now in my p.c many tnx and god bless.
Mar 14, 2008 | Shuttle MV42N (SHUTMV42N) Motherboard
MOTHER BOARD DRIVERS
i want to asrock prescott 800 mother boare drivers
Nov 21, 2007 | Asrock K8Upgrade-VM800 Motherboard
Panasonic PT-47WX49 47" Rear Projection Television Logo
42 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
