Question about Cameras
Goes through AA batteries within one hour of use
  • Ty Price May 11, 2010
    What is the camera? What batteries does the manual suggest are the best to use? what are you doing that uses up the batteries that fast?
  • Cameras Master
  • 4,738 Answers
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation. Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Posted on Jul 17, 2009
How many hours will 4 AA lithium batteries power a constant draw of 2.5 watts?
2.5 Watts sounds pretty high for an LED strip. If the batteries are paralled and the applied power is 1.5 Volts, then you will be pulling 1.6 amps - the batteries won't last long at all. The batteries are good for around 2500maH, (Milliamp hours). so figure you may get around 2 hours of life for the batteries.
Jan 14, 2013 | Audiovox Energizer Lithium Batteries 2...
The battery does not seem to work anymore as it should be a rechargable battery. Even if i charge it for more than 8 hours, the battery goes out quickly. I want to know what kind/type rechargable battery...
In most shavers it is possible to strap the EQUIVALENT VOLTAGE/CURRENT cells in series/parallel to give the correct specified rating needed for the battery. If the original is hard to find or is very epensive I have tried many times to change with AAA or AA with rating of over 1000mA cells to be soldered together as required.
I hope you can remove and check the spaces within to try with this arrangement. If not replace with the original from Panasonic.
Jul 20, 2011 | Panasonic ES 366 S Electric Shaver
Hello, i am from Greece and i represent one young and famous Greek singer.We use the psm 900 on stage and the batteries need to be replaced within one hour from the first use.So, we need to do this 2-3...
Shure's spec is that you should get 5 to 7 hours of CONTINUOUS use. There is OBVIOUSLY a problem.
First thing to check is what brand batteries you are using... some cheap ones from "C" have only a fraction of the energy content as name brand ones.
Second thing is expiration date on the batteries.
Next is to check the current drain of the bodypack with aa meter and compare to the specs for the battery. A good AA should deliver 2000 maHr.
The last thing is to realize that you CANNOT use rechargeable batteries in these devices. The rechargeables have a lower voltage and the circuitry will cut off MUCH earlier than with alkaline batteries. I would expect rechargeables to fail within 1 to 1.5 hours in this unit. As the rechargeables age, it would become much worse.
Mar 04, 2011 | Shure PSM 900 Bodypack Receiver
There seems to be humidity in the watch
If the humidity has been condensing or happening for a period of tmie longer than 3-4 hours, this watch should be taken to a Certified Master Horologist in your local area as soon as possible. The timepiece should be opened, dried out, resealed, and water tested.
If humidity comes and goes away within 3-4 hours it is a normal occurrence from extreme temperature change (A/C to outdoor heat, vice versa) (Outdoor cold to indoor heat, vice versa).
Jan 16, 2011 | Giorgio Armani Emporio Armani AR0584 AA...
Recently I purchased Sanyo Eneloop NC-MQN04ES Charger. I need the user manual for this charger. How many hours does it takes to charge 4 aa and aaa Batteries. I charged it for more than 6 hrs. But the led...
This is from the user 's manual i just copy paste it
Specification: Voltage : AC 220V - AC 240V,
Input : 50/60 Hz 6W,
Output : DC 2.4V 220-280mA x2 (AA),
100-140mA x2 (AAA),
LED indicator : ON - charging OFF - Timer off (approx 16hours) Battrey/Charge Time Approximate Hours :
-Eneloop Ni-MH AA (typ 2000mAh) 10(h),
-Eneloop Ni-MH AAA (typ 800mAh) 8(h),
-Ni-MH AA (typ 2700mAh) 13(h),
-Ni-MH AA (typ 2500mAh) 12(h),
-Ni-MH AA (typ 2100mAh) 10(h),
-Ni-MH AA (typ 1700mAh) 8(h),
-Ni-MH AAA (typ 1000mAh) 10(h),
-Ni-MH AAA (typ 900mAh) 9(h),
-Dimension : 118 x 75 x 40 mm
Jul 03, 2010 | Vacuums
Zoom H4 Battery Problem
I am having the same problem with my Zoom-H2. I have 2 2650 mah rechargeables, and the draw is such that 20-30 minutes of record &/or playback kills the batteries. Last night I just turned the power on and did nothing. 5 hours later the batteries were dead...
This isn't a solution. It is a reaffirmation that you aren't crazy!
Jan 05, 2010 | Zoom H4 Handy Recorder
Product: Radio Shack personal emergency dialer,
are those recharbale batteries?
if they are, its probably the problem
when a rechargeable batt goes old it holds less
Dec 29, 2009 | Lands Phones
What kind of rechargeable battery goes in the Kodak Easyshare Z710?
Z710 can use:
KODAK Rechargeable Ni-MH Batteries (AA Size): These Ni-MH AA batteries last up to twice as long as alkaline batteries when used in your KODAK Digital Camera and KODAK EASYSHARE Ni-MH Rechargeable Battery Pack: Provides exceptional capacity with its 2.5 hour fast charge cycle time; can be recharged up to 1000 times in the EasyShare Camera Dock or EasyShare Rapid Charger.
For more information on your camera plese follow this link:
http://www.kodak.com/global/en/service/products/ekn032171.jhtml?pq-path=9374
Dec 17, 2009 | Kodak EasyShare Z710 Digital Camera
Cameras Logo
37 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
