Question about Brother HL 1230 Laser Printer
I did a front feed on my Brother HL-1230 printer and now the cheque is jammed in the printer. How do I get to the drum to remove the cheque?
    Problem Solver:
  • 14 Answers
Open the front of the printer via the 2 tabs on the sides of the front door. Lift the toner/drum assembly out of the printer. You should be able to see the paper in the unit. Carefully pull the paper out of the unit. You may want to run a few pages through the printer to pick up any residual toner before printing another document.
Posted on Jul 17, 2009
Brother HL - 2150N Paper is jammed inside printer; how do I remove it ? URGENT - business printer... thank you!!
Open the front cover, remove the toner/drum cartridge.
Open the rear cover, look for a jam lever you can press down then remove the paper from the back.
If you try to pull the paper out through the front you can damage the gear system.
Use both hands to try and limit the possibility of tearing the paper.
Jun 14, 2011 | Brother HL 2140 Laser Printer
My paper keeps jamming after I changed the drum of my printer in my Brother HL-5250DN printer-- it seems that I touched something when I did so.
1. Unplug the printer.
2. Remove the drum.
3. Make sure there are no obstructions. Check for pieces of paper obstructing the feed and any small objects such as torn paper or even a stray fingernail.
4. Replace the drum.
5. Plug in the printer.
6. Attempt to print again.
Mar 02, 2011 | Brother HL 5250DN Laser Printer
How to remove paper jam in brother hl-2140
Open the front door, remove the cartridge/drum...slowly slight the paper out. if it jams at the back ...do the same but rotate the fuser gear..if it jams on the tray not pull as it would cause the paper to break and sensors might get dmaged,
Sep 22, 2010 | Brother HL 2140 Laser Printer
Paper light keeps blinking, paper full, won't print
Paper light blinking could mean a few things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 12, 2010 | Brother HL-2040 Laser Printer
Got a paper jammed in my brother hl-2170w
Open the front cover of Printer, remove the drum and toner with force and put aside. Remove the jammed paper slowly so it doesnt rip. If you cannot find the jammed paper check in the back cover and paper tray.
Apr 03, 2010 | Brother HL-2170W Laser Printer
Paper light flashing on my brothers HL-2040 printer. I fanned the paper still keeps flashing
Hello ,
Please follow the below steps to try and clear this message.
  1. Turn the power off on the unit.
  2. Open the front and back cover of the unit.
  3. Remove the drum and toner cartridge from the unit.
  4. Check thoroughly inside for any paper jams or any other foreign objects and remove them.
  5. Reinsert the drum and toner and close the front and back cover.
  6. Turn the unit back on.
If the light keeps flashing you will want to check to see if you need to feed paper through the manual feed.
The manual feed is the opening on the front of the printer, just place a page there.
This should clear the error message on the display screen and allow you to resume normal use of the printer.
Thanks,
Pat
Mar 28, 2010 | Brother HL-2040 Laser Printer
Paper jam
Please open the front cover and remove the drum to check the jam. If not in the drum, then check the back cover, open it to remove any jammed.
May 12, 2009 | Brother HL-2070N Printer
Non stop paper jams
I had this same problem. I finally noticied that the problem occurred consistently on the right side of the paper feed. I discovered that a little part along the right side of my drum unit (just inside the paper feed area) had disconnected and was loose inside the drum unit itself. Once this little part was placed back into it's rightful place, VOILA! Problem solved! Hope this helps!
Jan 22, 2008 | Brother HL 5140 Laser Printer
Printer reset re Brother HL 1230
Resetting the printer should clear the flashing leds (flashing lights.)
How to Perform A Factory Reset:
1. Turn the printer off.
2. Hold in the circular button on the front panel of the printer.
3. Turn the printer back on.
4. When the DRUM light is lit by itself let go of the button. Hold in
the circular button on the front panel again. Once the Alarm light comes
on, let go of the button. This has performed a factory reset on the printer.
If the alarm continues, the printer may need service.
This issue is listed by Brother. Click here to view
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Oct 22, 2007 | Brother HL 1230 Laser Printer
Paper JAm
There are three places to clear the jam: 1. Paper tray (remove it and feel inside, clear paper. 2.Open the front (above the manual feed slot) inside is the drum - remove that and the toner cartridge, if necessary. 3. On the back - open the rear chute. You should be able to remove the paper in one of those areas. See the Brother web site for complete pictures ans instructions. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_006.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=4
Aug 20, 2007 | Brother HL-2040 Laser Printer
Brother HL 1230 Laser Printer Logo
88 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
