Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Will only produec 20lb of pressure
Will only produce 20lb of pressure
    President:
  • 1,273 Answers
I have the same make/model. Connect a device to your air line (impact, blow gun, doesn't matter anything that will use air). Operate the device and note if the pressure on your output gauge falls, and then rises back to 20# when you let off of the device. If it does, this indicates that your regulator is either defective, or it is adjusted too low. Try adjusting the regulator knob, operating it in both directions, and note the pressure on the output gauge. If you can get it to rise, you're home free!
Regards, --W/D--
Posted on Jul 18, 2009
How to quick thaw a 20lb. turkey
quick thaw a 20lb. turkey Willie, in the sink, with cool water, you will have to continuously turn and run new water over bird until you feel sufficiently thawed. I find this method better then microwave thawing.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 26, 2016 | Refrigerators
Pump not holding presure
If you have a bladder - type water pressure tank, it probably needs to be purged of air and then pre-charged to 18 psi. There may be directions on the side of the tank. Turn the water Pump off. Drain the tank of water. Check the pressure of the tank at the air valve on top of the tank. The pre-charged pressure of the bladder is set to 2 psi below the lower pressure set by the pressure switch, so in your case, the low end pressure is 20 psi. Therefore, the pre-charge pressure of the tank is 18 psi. If you set the pressure switch to operate at 30 -50 psi, then the pre-charge pressure would be 28psi., etc. Once the pre-charge pressure is set, turn the pump back on. ( don't forget to close the drain valve). The system should cycle normally. A tire gauge works to check the tank pressure. An air compressor may be used to charge the tank, but be careful not to over- inflate the bladder. A tire air pump may also be used. Hope this helps....
Apr 06, 2014 | Utilitech Plumbing
Can a 20lb tank be hooked up to a Coleman 2 Burner Stove 5430A
Yes. There are multiple adapters made to fit this application. Your local walmart most likely will have them. http://www.walmart.com/ip/Coleman-5-High-Pressure-Propane-Hose-and-Adapter/19897422
Sep 18, 2013 | Coleman 2 Burner Propane Stove 5430E700
Oil pressure
My 5.7 GM engine was doing this... half a bottle of lucas cured it..(pint)
Heavy Duty Oil Stabilizer
Aug 08, 2017 | Cars & Trucks
Printer picks several pages at a go instead of one. What can I do?
Riffle the paper a few times prior to putting it in the infeed tray. You might try inverting the paper to see if one side is more prone than the other to the stacking problem.
If you have the luxury of being able to adjust the infeed roller pressure (to accommodate different paper weights), adjust it for your paper weight (20lb, 24lb, 64lb, etc)
Apr 13, 2013 | Epson Stylus Photo Px660
I have a 99 mercury cougar that won't start, it's
Have you ran an Oil pressure test? low oil pressure (20lb)or no oil pressure(0lb)and the lifters will not open the valves enough to let fuel in to the cylinder to start your engine!
Dec 02, 2011 | 1999 Mercury Cougar
How do i set the low pressure on the flotec switch
your pump should have a 20lb seperation ie. pump turns on at 20lb and off at 40lb or on at 50lb off at 70lb. under the cover of the switch theres two screws with springs under them.dont mess with the small one.the large one if you screw it down (right) will increase the pressure while maintaining the 20lb separation. one thing to keep in mind its fine to adjust the pressure BUT at the same time the air pressure in the tank needs to be adjusted to two lbs below the cut in pressure of the pump.
I believe the directions are in the top of the cover of the switch
Jan 02, 2011 | Flotec TC2151 P2 Well Pump Pressure Switch
I have a ProCom ML150HPA for propane and would like to use a 20lb bottle the manual states that at least a 100 lb tank is required. With the 20 lb the pilot lights but will not stay liit without the...
The reason for a larger tank is so the LPG can vapourise enough to supply the heater using a smaller bottle it may freeze and not produce enogh gas
Dec 13, 2010 | Procom MN100HPA Heater
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
118 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
