Question about KitchenAid KESC307 Electric Kitchen Range
KESC307 Oven Door
The inner glass on our oven door broke, we have purchased the glass from kitchenaid but now do not know how to go about taking the door apart and installing it.  Can you please help?
Thank you
  • 833 Answers
Hi Mcrae...
Generally, the procedure is a straightforward mechanical one.
First, check below the door for screws and remove them. Next, open the door and find the screws on the side and inside of the door. Remove them. Careful...when the door panel comes off, the door will be much lighter and will slam closed if not restrained. The panel should 'fall away' from the door. Have someone assist you here! At each stage, take a digital picture of the disassembly so you can assist yourself in putting it back. Clean the glass with a blue cleaner and buff out. Use a scrubby or very fine steel wool to gently remove any stains from the old glass you're reusing. Do this on a bedding of newspaper. Always handle glass by the edges.
When installing the glass, it should generally be apparent which way it goes in. Some glasses have patterns on them which correspond to the door opening...if it is the outer which is being replaced. Note them. There may be an up or down as as a result. Any foils or patterns are positioned to the direction you won't have access to later.
You'll likely need a second pair of hands to put it all back together. Take your time. Don't force anything. Tighten screws evenly.
Posted on Dec 03, 2007
Replece glass oven door kitchenaid kebs278dss8
Oven doors have at least two panes of glass (air gap between so little ones touching outer glass do not get burned). You remove the screws around edges of door (top, sides, & bottom) and lift frame up and forward to get outer face off. The glass in ovens is tempered to take heat so you can not just use regular glass. You will find outer piece is sometimes the entire size of door but is painted black with the "dot" pattern that lines up with inner piece. Once you get face / frame off you will usually find the handle screws and mounts for inner glass. Sometimes inner glass sealed with high temp sealant. But make sure you use correct glass or someone could get hurt.
Jan 21, 2015 | KitchenAid Ovens
KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
Jan 02, 2008 | KitchenAid KEBC277 Electric Double Oven
Cracked inner oven glass window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
Jan 16, 2011 | KitchenAid Ovens
Kitchen aid double convection oven - glass needs cleaning!
Had to remove the screws on the BOTTOM of the outside door, then panel came off after all the screws (inside oven door included) were off...
Reversed the order to put back on.. Cleaned (all) three glass pieces nicely... Now after reading the problems with the self cleaning part (doors getting stuck!) - I'm afraid to try mine!
Jan 22, 2010 | KitchenAid KESC307 Electric Kitchen Range
Inside oven door glass broken Can I replace broken inner oven glass myself? I broke it today and need some help.
I would guess that you could not. It is a safety glass and has a special gasket material. Although you may be able to buy the door as cheap or cheaper than just the glass plus the install. Hope this helps. Have a great day.
Apr 17, 2009 | KitchenAid KGSC308LSS Gas Kitchen Range
Kitchenaid superba Stove Door
Slid the bottom storage compartment completely out. On the bottom of oven door are four (4) screws that hold trim piece that support outer glass panel. Remove screws and carefully remove complete glass and trim assembly. There are two (2) corner trim panels that are also secured by two (2) of the screws being removed. At this point you can clean all glass (both the outer panel that was removed and the inner insulated glass) and all other built up goop. Simply reverse process to reinstall.
Aug 04, 2008 | KitchenAid KESC307 Electric Kitchen Range
How to replace inside glass on KitchenAid KERC608 Type 30P Range
Open the door fully and with a small screw driver, look closely at the hinge area on the oven cavity. There you will see a small lever that will rotate down and lock the door in place. Once in the lock position, begin closing door, you will feel the door 'catch' then lift the door off of the oven.
Jun 16, 2008 | KitchenAid Kitchen Ranges
Broken inner glass on kitchaid range how to remove the door
screws near the hinge, make sure to get oven/tempered glass sometimes the screws are located in the crack between the oven and door on the bottom
Jun 12, 2008 | KitchenAid KGST307 Gas Kitchen Range
How to Dismantle Oven Door to Clean Glass
yep but it isn't worth it in my opinion if you want to know i can tell you its a pain and usually you cant get it all off because its baked on but if you want to do it just reply to your own message and ill write procedure in the morning there is about three or four pieces of glass in there insulation all kind of stuff lol -tech17
Dec 29, 2007 | KitchenAid KESC307 Electric Kitchen Range
Spill into oven vents
The best way to clean the inner glass is to remove the door from the oven. With the door in the broil open position (first stop) pull up for about 2 inches until the hinge brackets are released from their stops. Close the door all you can and lift the door off the hinges. Lay the door on a padded surface and remove the 4 screws on the bottom. The outside glass will now slide out of its rail and you can clean the inside. To install just reverse the process. If you take your time and observe, it's not that bad of a back.
Nov 26, 2006 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
461 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
