Question about Lucent (700057144) Router
How to fix connection that was not detect by lucent router. a message show "limited connection or no connectivity"
    Sergeant:
    Champion:
  • 249 Answers
Reinstall Drivers.
Posted on Jul 16, 2009
No connection to wireless network
Is this an open wireless router or do you need to enter a security key code? Best get sp3 installed it also may fix this issue.
May 30, 2013 | Computers & Internet
Tip
How to fix limited or no connectivity message with your wireless network...
How to fix limited or no connectivity message with your wireless network connection
When you move between wireless networks that use the same IP range and/or hardware it is some times necessary to manually renew your IP address for the new network because the computer still thinks it is connected to the old network.
Note sometimes all you need to do is reboot your computer and the computer will reacquire a valid IP address but from time to time a reboot will not fix the problem and you will need to go through the steps below.
1. Click Start - Run
2. Next enter "CMD" and click OK
3. Now at the command line type "ipconfig /release" and press Enter
4. After the first command runs you will be at a command line again now type "ipconfig /flushdns" and press Enter
5. Now you will need to enter one more command, type "ipconfig /renew" and press Enter
At this point if you are wireless connection is not already connected it should be reconnecting to your router.
If you still get the limited or no connectivity message make sure that the router is getting an internet connection. You may need to restart your modem then your router to make sure that the router is connecting properly to your modem.
Also note in my example pictures you can see several connection listed this is because my notebook is connected to several networks. If you have a high number of connections you may need to reinstall the drivers for your network card. Doing this will dump and cached setting that may be causing your connection problems.
on Nov 20, 2010 | Computers & Internet
Message linmited access and cannot connect
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Mar 16, 2013 | Linksys Wireless-G WRT54G Router
When i my pc on it show me generic host problem after this msg windows stop network services?anyone tel me
You may occasionally get an error message that reads "This connection has limited or no connectivity. You might not be able to access the Internet or some network resources." It indicates that your PC is having a problem trying to access your network device to connect to the Internet. Very often, a bug that typically affects Windows XP Service Pack 2 causes this error message. This bug causes a loss of your network connectivity in workstations that use Microsoft's L2TP-based VPN (virtual private networking) client to connect to the NAT-based networks. You can fix the "Limited or No Connectivity" problem in a few steps. (If your connection works but you still get the error message, go to Section 2 to learn how to disable it.)
Review the following symptoms and determine if you experience any of them after you install the Windows XP Service Pack 2:
You get the error message "Limited or No Connectivity" when you attempt to connect to your network.
You have a problem connecting to your local area network or to the Internet.
You keep on receiving an error message: "Acquiring IP Address" message. If you experience these symptoms after installing Windows XP Service Pack 2, then this bug is causing the problem. In this case, go to Step 2; otherwise, skip to Section 3 Download the Microsoft patch (KB884020) from the Microsoft website. Run this update to install it. Create a registry fix by launching Notepad and typing: [HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Services\\IPSec] "AssumeUDPEncapsulationContextOnSendRule\"=dword:00000002 Save the file as FixReg.reg to your desktop. Double-click the saved file to install it into your registry. Restart your computer and the error message will likely be gone. If you still see the error message, follow the steps in Section 2. b> If Your Connection Works But You Still Get the Error Message b> Navigate to the "Start" button and select the "Control Panel." Double-click on the "Network Connections" icon. Right-click the "Local Area Connection" icon and select "Properties" from the popup menu. Click on the "General" tab. Uncheck the option that is labeled "Notify me when this connection has limited or no connectivity." Click "OK." b> If the Patch Doesn't Fix the " Limited or No Connectivity" Problem b> Check your DSL router for any malfunctions. Re-configure or power cycle your router. Check your computer's network card configurations and network cabling to ensure that the problem does not lie here. Check your firewall to determine whether it is blocking you from connecting to the network or to the Internet. Disable the firewall and attempt connecting to the network or Internet while with the firewall is disabled. If the firewall is causing connection problems, then reset or uninstall and re-install the firewall. Reduce your connection speed to 10 Mbps and test this to determine if it fixes the problem. To do so, navigate to the "Start" menu and select the "Control Panel," "System" and "Device Manager." Review the properties of your network card. Click the "Advanced tab." Locate the "Link Speed and Duplex" section. Change the settings from "Auto Detect" to "10Mbps/Full Duplex." Hope this helps.
Dec 24, 2012 | Computers & Internet
I have windows 7 home prem and cannot connect says detects strong signal but limited access
Most likely, the access point is not connected to an internet gateway whatever that is at your place.
and since access points does not provide DHCP service by default (handing out IP information to connected clients), you get the limited access message.
In short, make sure the access point is connected to the router because the router is the once responsible for providing the DHCP service.
Feb 18, 2012 | ASUS WL-330 802.11b Wireless Access Point
"limited or no connectivity" showing
musazmusaz
If you are getting the "limited or no connectivity" message you may not be getting a good IP address from your router. The link below will help you reset your IP address.
http://www.fixya.com/support/r6915776-fix_limited_or_no_connectivity_message
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jan 17, 2011 | Linksys Wireless-N WRT150N Router
The wireless computers on the network are working. The computer that is wired to the router keeps giving the message Cannot renew IP address. The icon shows limited or no connectivity
reset the router if not change the network cable. if it does not fix the problem you need to call your internet provides be cous my be need to configure the settings from router
Nov 22, 2010 | 2wire 2700HG-B Router (2700HGB)
Network status is "Limited connectivity
Sometime the wireless card does not connect to the wireless router properly and you will get this error message. To fix, right click on the wireless icon on the Task Bar and then click Repair and the wireless router will issue a new IP address to the wireless card in your computer/laptop.
Connection problem. shows limited connectivity and disconnects
limited connectivity means you didn't get an IP address. Is the router set to give addresses via DHCP, or is another PC doing that? Most common cause of this problem is wrong authentication (normally "open") or encryption type (WEP, WPA or WPA2). Pklease note that encryption keys can be set as HEX or ASCII, if they are HEX it will be only numbers 0 to 9 and letters A-F. ASCII can be anything.
Jun 01, 2009 | NetGear DG834N Router (DG834N-100AUS)
Need portal to Lucent rounter in order to configure PPTP
What model Lucent router is it? If it's an older one (DSLPipe, for example) it won't be able to handle the PPTP connections due to a hardware issue. If that's the case, the best solution would be to request that your ISP (if they supplied it) disable NAT on that router and assign you a block of public IP addresses. That way the router will just directly pass on the traffic to your IP address and VPN would work just fine. Regarding a phone number, Lucent was merged with Alcatel in April of 2006, so you may need to contact them. Their contact numbers can be found here: http://www.alcatel-lucent.com/wps/portal/ContactUs
Sep 14, 2007 | Computers & Internet
Lucent (700057144) Router Logo
48 people viewed this question
Top Lucent Computers & Internet Experts
John Anderson
John Anderson
D. E. Hev
Coss
Are you a Lucent Computer and Internet Expert? Answer questions, earn points and help others
