Question about Mitsubishi Televison & Video
No picture constatant pounding sound when you turn up volumne, power button comes on screen is black. thumping sound comes thru speakers.no other activity going on. mitsubishi 52'' projection screen not hd. about 8 years old
  • jmphins Jul 20, 2009
    the model number is vs-50501a. when i listen from behind the set i hear a constant snapping sound but the sound comming thru the speakers is a loud pounding. thanks for any help you can give me or a round about estimate to fix the set . thanks again.
  • Mitsubishi Master
  • 5,807 Answers
there might be circuit failure inside your TV systems,first we check on the power supply output voltages, it may not have enough to power up the horizontal deflection circuits.
here is a guide for you.
if you have a multimeter measure the voltage on the capacitor after the diode of chopper secondary windings.that would be the B+.
maybe the supply rail B+ is only about 45V or still lower
solution : replace the horizontal deflection flyback transformer maybe partially shorted
maybe no voltage at all
solution : check horizontal output transistor might be defective, replace if found shorted
maybe there is a good supply say at least 110V , but no oscillator drive on the horizontal output transistor, or blocked oscillator signal drive
hope this helps, thanks for using Fixya!
Posted on Jul 21, 2009
  • 10,594 Answers
Please intimate exact model of your Mitsubishi TV that is written on sticker pasted at back. Model number will help me to look into its schematics for possible reason of problem and its possible solution.
Thanks.
Posted on Jul 19, 2009
Makes large thumping/chirping noise when turned on. Its not even connected to the receiver
Since you have said the speakers make this sound when "turned on", I'm going to assume there's some form of power amplifier attached (internal, external or otherwise). Based on the minimal information provided here, this simply sounds like the normal reaction of a speaker when the amplifier is turned on. In short, an audio speaker is a type of "transducer" and when power is applied (thru some form of amplifier), the cone reacts to the power surge and causes a thump, pop or other noise. Turn on your TV for example and you'll usually hear a small pop from the speakers...and a larger/more powerful amplifier is likely to make a louder noise. Without further information, in most cases this is quite normal.
Assuming there is an external power amplifier, my advice would be to turn the volume on the amp (regardless of whether there's a receiver connected) to 0 before turning the power on. If it still makes such a noise, it's possible the volume control of the amp may require cleaning.
Good Luck!
Apr 01, 2016 | Audio Players & Recorders
No picture but the red power button blinks each time it blinks there is a thumping noise from speakers and a clicking sound
try checking the fuse area, together with the capacitor & resistor may one of them is faulty. and also check for any bad soldered.
let me know
Oct 31, 2008 | Haier HTF27R11 27" TV
Polaroid flm-3701 monitor no power
Hi Cliff. the control board (as seen here: http://www.ebay.com.au/itm/like/251052948534?lpid=87 ) May be the only option. But once one thing has gone others may follow, ie Even the screen itself may have been hurt. I would highly suggest to throw it out and just buy another screen. Note, that model does NOT come with any 'fuses' inside, hence probably why it sparks still.
Nov 09, 2013 | Polaroid Televison & Video
Amp will play at low volumn but not when turned up
probably.
almost sounds like your speakers are worn out, and when you turn the volume up, they clip n no sound comes out.
Jul 31, 2010 | Alpine PDX-4.100 Car Audio Amplifier
Black screen, hear voices , but no picture playing?
check your screen back Light or get a working screen and test it or your screen flax is bad
Mar 31, 2017 | Mitsubishi WD-73C9 73" DLP TV
Vizio speakers make a buzzing noise
The audio board on your 47" Vizio has gone bad. Replace that board will fix the problem.
Jan 21, 2009 | Vizio VO47L 47 in. LCD TV
Thumping sound (like a heartbeat) through speaker (no picutre comes on)-Toshiba TW40X81
This may be a "ISL9860" chip on your T-con board - I saw a nice youtube video by norcal715 you can do a web search for "norcal715 samsung" & a few from him will pop up. The one I watched was at https://www.youtube.com/watch?v=l2jzLn5QEos
You might contact him through his youtube video.
good-luck.
May 02, 2017 | Toshiba TW40X81 40" Rear Projection...
Thumping
when I turn on my tv there is a black screen and a loud thumping noise.What do I do?
Jul 29, 2008 | JVC AV-48WP74 48" Rear Projection...
Tv will not come on....it was on a few minutes ago
as you say that sound is not ok other thing is normal please check the following 1 speaker and its wire for loose 2 supply to sound section and loose print 3 parts in audio out put section kids can not create any problem from outside. regards
Sep 09, 2007 | Curtis-Mathis CM19011 TV
TV Comes On But No Picture
check for bad solder connections on the pc board and a posible leaky cap
Dec 06, 2006 | Philips Magnavox 20MS233S 20" TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
