Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
It sucks fine but is not blowwing out very strong
  • 297 Answers
Sounds like air lock, but we will
try 2 things before turning back on
check hose where it goes into the pump sometimes hair builds up on the grate in the housing and catches other bigger debris
blast your cartridge filter with the hardest setting from your garden hose from top to bottom and flip then repeat
now put it all back together make sure to unscrew the bleeder cap at top of cartridge housing
open inlet on the suction side and wait for water to come out of the bleeder cap
now open the outlet side
now turn on filter pump and run for 20-30 seconds
now close bleeder
all air should be out now
Posted on Jul 17, 2009
I love the machine because it sucks up the dirt but it also sucks up the rug fibers and is clogging the hose. How to I clean out the hose?
Try this - run a strong string with a small weight attached down through the hose. Tie a small rag or a sponge to the end of the string and pull it back through the hose.
Dec 04, 2016 | Vacuums
Hose sucking flat
I'm assuming this is on an above ground pool? You may have to replace the suction hose with a better quality one. Once the hose "flattens" it will not be very strong again. Replacements should be available at a local pool store.
Mar 27, 2013 | Pool & Spa
How to do I convert it from blower to vacuum..it just stopped sucking and the blowing is not strong
My LEAF HOG works fine on blowing - but when I switch to vacuum it wor't
start. What's the difference from going to Vacuum from Blower???
Dec 03, 2010 | Black & Decker & Leaf Hog Blower / Vacuum
It seems as if the sucking power of the pump is too strong because one or two pipes become sucked quite flat and then the barracuda doesn't work properly. Why is this?
Replacing the flattening hoses will resolve the problem.You might want to check the suction and keep it at the lowest amount necessary to run cleaner.
Mar 17, 2010 | Zodiac Baracuda Zippy Pool Cleaner
The suction in the hose of my 2 year old Dyson Animal vacuum is compromised. I may have sucked up a small cat toy or something. Regular vac still is fine. The hose "sucks closed" after a few seconds near...
Hi there, it sounds as though the wand handle is blocked. To test this, remove the wand handle from the hose and test the suction at the top of the hose. If its strong here, then you will need to remove the blockage from the wand handle. If the suction is still poor, you will need to remove the hose by pressing in the catch on the hose cuff near the base of the machine and removing any blockages.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Dec 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
The fuse bloww try replacing it but keep
Has this air conditoner been running on these fuses for awhile, and is it just now starting to blow the fuses? If so then have a short in the air conditioner. If this is the first time you're trying to run this unit on these fuses, then you need to check the rating plate on the air conditioner for the full or rated load amps and see if your fuses or the outlet rating will carry the amps the unit is drawing.
Aug 10, 2009 | Heating & Cooling
Ps 3 games freeze after 10 to 15 minutes ps and ps 2 games play ps 3 games freeze after 15 minutes
unit maybe internally dirty not letting it cool properly get canned compressed air and bloww out throughly!!! :)
Jul 05, 2009 | Sony Playstation 3 (PS3) Console
Strong sucking in hose
Sounds like either the stiffeners within the hose have failed, or there is a blockage as you mentioned.
See if the hose feels weak at the point where it collapses. If not, look for a blockage in the vacuum head, or remove the hose at the vacuum head end and look for a restriction in the hose or the vacuum head port.
Jan 23, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
241 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
