Question about Razor MX500 Dirt Rocket
Got wet will not start after son washed it - Razor MX500 Dirt Rocket
  • 34 Answers
Hi there. drain off all the petrol, take off carburetor and if it parts at the bottom remove float chamber,dry it inside and refit,part any wired sockets and give terminals a good spraying with wd40,pay good attention to the sparkplug lead and coil give these a good spraying too,spray ANY exposed leads you can see,pop off the crankcase (wired side) again a good old spray on all components. do not be tempted to wipe off any wd40 spray, just leave all that youve coated, wet, then fit new spark plug,check you have a spark before fitting by inserting plug into plug cap then grounding the exposed metal of plug on engine casing(holding with insulated pliers) if theres a spark...bingo... refill with fresh petrol and away you go,
this always worked for me on my motox bike that had been over exposed to water,which seems the case with yours,
tip: before and after use always give everything a good spray with wd40 or other similar product,it will expell any water ,believe me it works and saves a lot if headache.
hope this helps!
regards
dave.
Posted on Jul 26, 2009
  • jarma Jul 26, 2009
    sorry... presuming its a petrol powered bike!!!!
  • 31 Answers
Not a great expert on motobikes but make sure there is no water in the exhaust and that the spark plugs arn't wet.
Posted on Jul 23, 2009
Kymco k pipe has no electrics after washing it is blowing new fuses
Hi, Lynn if you have access to compressed air you need to blow out the excess moisture in the fuse panel and all electrical components that may have gotten wet otherwise you will just have to wait until everything dries out naturally, may take 2-3 days depending on where you live for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
washed bike now blowing main fuses
http://www.stromtrooper.com/dl650a-2012/89929-blown-main-fuse-after-wash.html
Main fuse blowing after washing bike
KYMCO ZING 125 Manual
Jul 27, 2016 | Kymco Motorcycles
Tip
THANK YOU !!!!! and thanks to my 15 yr mechanically inclined son...he did do...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F02” error code.
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. Check the drain hose to make sure it is not kinked or clogged.
  2. Check the electrical connections to the pump and ensure the pump is running.
  3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
on Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
No power after washing
Did you wash it with the seat off? Sounds like you got the relay wet, or fusebox wet.... take the seat off, let the bike set in the sun for a couple of hours....hopefully whatever you got wet will dry out and the bike will start.
Mar 22, 2014 | 2007 Honda VTX 1800 C
Hi! re BOSCH washing machine WET 2820 Program will start, and then for 30 secs approx start normally, water starts to enter the drum. Then it stops, nothing happens. I have cleaned the soap dispens
BOSCH washing machine WET 2820 This video will show you how to change the door eal washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 07, 2011 | Bosch WET 2820 Front Load Washer / Dryer
Hello....my tumble dryer was working perfect until my son decided to put soaking wet washing into it....and i mean soaking wet....now the drum doesnt turn but the heat still comes out....please help as...
did the belt come off due to heavy load? if it is still n and didnt blow a breaker it may have blew the motor, you would have to take the back off to inspect, dont forget to unplug first
Jan 18, 2011 | Dryers
\\\my washer flashes a F 21 and doesn't open. I washed my son's comforter the other day and the machine stopped and flashed a F 21 and would not open. when I finally kept pushing the unlock button a...
Your blanket probably caused an out of balance on the tub which caused the washer to stop in the middle of the cycle. The lock switch is a time delayed switch. Requires several minutes before it is activated to release. When washing single items you need to add another clothing item of approximately the same weight to create a balance during spin.
Dec 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
MY SON LOADED A LARGE AMOUNT OF CLOTH INTO THE WASHER AND WHEN THE SPIN CYCLE CAME ON THE WASHER STARTED MAKING A HORRIBLE BANGING NOISE. it does not look like the springs are broken but the washer seems...
I'm suprised the unit was not able to spread a large load around to balance the drum. Maybe some item bunched up and made one side heavy. For a front loader, a proper load is just about all you can cram in there dry. You'll notice when the clothes get wet, they take less space, and when they are spun, there should be lots of room in the middle.
Apr 29, 2009 | Kenmore HE2 Plus Front Load Washer
LG Fuzzy Logic won't spin
I had the same problem with my machine. so i just jammed the sensor that deactivates the machine when it starts spinning wildly. doing this allows the machine to work it just sounds like its going to blow up for the first two or three spins and then it sorts itself out.
Dec 04, 2008 | Washing Machines
Ashtray
Vacuum it out at the car wash.... thats what I do.... then take a wet rag and wipe it clean
Jul 16, 2008 | 2004 Kia Optima
Wet dash
There's still water in it. You'll need to take the battery out and let it dry another two days. I got my phone wet one time and it took a week before it worked again.
Oct 15, 2007 | T-Mobile Dash Smartphone
Razor MX500 Dirt Rocket Logo
274 people viewed this question
Top Razor Cycling Experts
Erick Williams
Erick Williams
Level 1 Expert
Donald Ayers-Marsh
Lawrence Oravetz
Are you a Razor Cycling Expert? Answer questions, earn points and help others
