Question about Water Sport
Airbed won't inflate
I have a silent night airform airbed with built in pump that is supposed to inflate in minutes but it won't please help
I have the same product. i managed to inflate it using a pump i had for another airbed and inserting the largest size nozzle in the plug hole at the end opposite the built-in pump. took a minute to do once i gave up on the built-in pump!
Posted on Mar 23, 2010
Air leaking from cap on Ozark air mattress
There should be an internal one-way inflation valve that prevents leakage. The valve may be failing to close completely.
Aug 24, 2016 | Ozark Trail Velour Top Airbed Kit Queen
Pure Spa. where can I get an owner's manual?
Support - Intex
www.intexcorp.com/support/
The leader in Above Ground Pools, Airbeds and Inflatable Spas. ... Manual Pumps · Electric Pumps · Parts & Accessories · Electric Pumps · Floats & Toys · Pool Toys... If you don't find what you're looking for, get in touch with Customer Service.
2500 Gal Filter Pump (120v) - Intex
www.intexcorp.com/28633eg.html
Review the Trouble Shooting Guide in your Owner's Manual. Are any tools ... Can we use the pool while the filter pump is operating? Is it safe? No, due to ...
Oct 28, 2015 | Intex Pool & Spa
Can you find and seal a slow leak?
Finding the leak is the fun part as what you need to do is pump up the mattress and wipe an area with very soapy water to make bubbles at the leak site and do that until you find the leak
Then depending on where the leak is the repair is easy to very difficult
Easy will be any flatish surface to difficult a edge or seam leak
Take a look at YouTube for airbed leak home repair and delete code from there what you want to do
Sep 17, 2015 | Embark Twin Double High Air Mattress with...
The air mattress was working fine the night before and then last night did not want to inflate. The motor does not start, it is plugged in, the socket works. I plug it in and go to turn the know to inflate...
most likely if you pump is not working, the intake must be clogged preventing air from passing and cooling the pump. That's how pumps and things like hair dryer short out. Or something could be blocking the fan from starting.even the power cord could be bad, I would check those things and go from their.
Jul 08, 2014 | Swiss Gear SwissGear Queen Raised Double...
How do I apply the patching material with this product?
The package contains no instructions. clean surface with alcohol and let dry completely. I left my air mattress with very low inflation.
I cut a patch that covered well on every side. Mine was a n inch split on a seam. I applied glue to the slit and surrounding area, also to the entire patch. I waited about 30 seconds, just enough to reduce the fluid pressure, and met the surfaces, smoothing them out. I put some air in after a couple hours, the next day inflated as usual. so far, so good.
Jun 28, 2014 | Mountain Trails Airbed Repair Kit [80800]...
Pdw7800 won't drain
Is this washer new or has it been heavily used? Is the bottom of the washer covered with old food pieces or does it look clean? When it;'s supposed to drain do you here the faint sound of a motor/pump working or is it silent?
Jun 12, 2014 | GE 24 in. Profile PDW7800 Built-in...
My Sealy Right Touch air mattress won't stay inflated. How do I fix it?
Hi - we originally supplied the pump for Sealy and can sell you a replacement pump that will connect directly to your air mattress. The best way to confirm that it is the pump that leaks and not the air chamber is by switching the hoses at the pump. If the same side leaks it is the air chamber that leaks or the hose. If the opposite side leaks then it is the pump that leaks. Ferdinand 905 451 7243
Nov 17, 2012 | Cars & Trucks
What is an Airbed Pump?
By the question I guess that you don't own an airbed. An Airbed Pump is used to inflate air into airbeds mechanically rather than doing it by yourself which can take you hours and can be very exhausting.
Sep 04, 2012 | Bass Pro Shops Camping, Backpacking &...
My air mattress won't stay inflated. What's wrong?
If its just a small leak of air once in a while, don't worry. However, if you notice that the air is deflating considerably throughout the night you will need to check for holes.
Jul 31, 2012 | Camping, Backpacking & Hiking
Water Sport Logo
201 people viewed this question
Top Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
