placing a line down one side on the receiving end.
Comments:
Jul 16, 2009
- When sending out faxes (to anyone) from the Cannon CFX L4000 the receiving end is reporting that they are getting a straight line down- on one side of the paper.
Jul 16, 2009
- Mahalo (Thank You) for this clear and precise solution
its the problem of scanner glass on which you are placing the document to be faxed.from which thin glass the document passes on that glass either there is a hair like filament got stuck up and that is getting copied with all documents you send and that comes in all the receving faxes to others you send.get this glass cleaned and serviced internally as well as externally.also if still the problem.its the problem of inner circuit of the scanner a single point of the board is dead so its not copying and remainng black.so that board needs replacement.cost of the internal scanner circuit board under the glass is $30.
this are the only two possibilities.any of the one will help.check out.
Please do rate the solution. Thank you for using
fixya.keep updated. thanks
my canon laserclass 2050p fax machine keeps ringing I want to silence the ringer, but cannot find my...
(More)
my canon laserclass 2050p fax machine keeps ringing I want to silence the ringer, but cannot find my manual
At the top of a printed fax there is the companys name and because we bought our fax machine used to...
(More)
At the top of a printed fax there is the companys name and because we bought our fax machine used to I need to change it.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
