Question about Sceptre DCL9a
I also am having this problem. DCL9A flickers on then goes dark.
It only flickers on for an instant when first powered on or the computer is booted. Anyone been able to fix this one yet?
  • gremlingrn Jul 19, 2009
    I replaced all the larger electrolytics and now I have my monitor back. Thanks!
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 17, 2009
Dark horizonal lines
Hi! Only at booting, or all the way using the PC?
Mar 05, 2014 | ASUS G50 G50v G50v-x1 G50vt-x5 Series...
Dark screen and flickering on the laptop computer model pcg 61611L
I would check the GPU by connecting an external monitor before booting it, that will allow the external drive to automatically work.
Jan 02, 2014 | Sony VAIO Computers & Internet
I have a Dell Ultrasharp 1907FPV, it's a few years old. Whenever I start my computer, the moniter stays dark and the green power button does these quick flickers. Eash flicker cycle takes less then a...
You don't have a short-circuit. That would have blown the protections or even the monitor. Refer to the manual, that flashing light may be a code that tells you the problem. I don't think the repair would be expensive...
Nov 29, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
Monitor light flickers on orange never goes to green.
Sir,
You are suggested to check if you serial cable is in fine condition and it properly pluged into the Monitor and VGA. and do also try changing the serial cable .
Aug 30, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
My monitor works for a little while, then goes black.
Your power-inverter board needs an overhaul.
Probably in need of the standard capacitor replacement.
OR
a bulb in the screen is bad (a bad bulb will usually show symptoms)
It will flicker, or will look pinkishish for a bit or dark in the middle top or bottom of the screen.
ebaysbammbammfran
Oct 11, 2008 | E-Machines eMachines Monitor E15T4
Flickering then off
Problem is with Invertor Board maybe defective 2SC5707 transistors.
Samir
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
My dcl9a monitor goes black
How long has your computer been on when this happens? Does the power indicator light on the monitor change color when this happens? Also, if you jiggle the mouse or press a key on the keyboard, does the monitor display come back on?
Jun 21, 2008 | Computers & Internet
Viewsonc VA720 Flickers On and Off Continuously
Take a look at the capacitors and see if you have any weak one. An obvious way to spot one would be one bubbled up on top. A bad cap won't always be bubbled up. The monitor probably can operate until the voltage drops under 8 volts. Also possible if power supply check out good would be a weak backlight inverter.
Apr 05, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Volume quit very fustrating.
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 18, 2008 | Sceptre DCL9a
Problems with my DCL9A
As posted here http://www.fixya.com/support/t315752-dcl9a_white_screen.
Capacitors have many functions but I would most certainly check your powersupply inside the monitor. Capacitors are also used to remove the 60 hz Sine Wave Ripple (hum) that commonly causes interferance in electronics. Though the AC has most likely been converted to DC a side effect is pulsed DC. The capacitor charges up and slowly discharges to smooth out the pulse. A bad capacitor wont charge and discharge or work less efficient than before. Either way the whole point is . . .
Wether your experiencing a white screen or simply interference, check all components related to the power supply first.
Nov 04, 2007 | Sceptre DCL9a
Sceptre DCL9a Logo
630 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
