Question about Amana AFB2534DE Bottom Freezer French Door Refrigerator
Amana afb2534des not cooling either fridge or freezer. Where do I start troubleshouting?
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
had same exact problem - followed advice for fixing same problem in similar refrig. took of the back panel off the freezer section - 8 hex head screws - and found the cooling fins all frosted over.
Posted on May 31, 2008
Techsim
  • 59 Answers
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
  • 52 Answers
SOURCE: Side by side Amana freezer/fridge. When you close
Possibly need the hinges adjusted.
Posted on Jul 15, 2009
SOURCE: Fridge wasn't cooling but freezer was working, now both aren't
Hi,Your husband did good job, after cleaning and vacuuming, did freezer (bottom) have excessive ice?, if there's excessive ice in bottom, after cleaning, you have a defrost problem, but if there're no ice in freezer after cleaning, you got freon (gas leak) , there's a condensate loop, that passes through ref. body, from compressor that naturally develop, freon leak after few years, by rusting, normally it can be by- pass. vacuum and refill with freon, if there's no freezing, but compressor running, you'll need a mechanic, you got a freon leak. good luck.
Posted on Aug 10, 2009
Sea Breeze
  • 4655 Answers
SOURCE: refrigerator not cooling
You model if the ARB1950C has a defrost timer inside the fresh food compartment and behind the temperature control panel. Need to see if you can manualy turn the timer clockwise until the compressor stops. During that time of 25 minutes the freezer should be in defrost. I believe your timer needs replaced based on how you explained what is happening. The part number for your timer is 67001036 and can be found at the links below. If it stays longer that 25 minutes then it's sticking in the defrost section of the defrost timer and will need to be replaced. If your refrigerator does not restart after about 25 minutes then slowly turn the timer through the opening in the plastic cover. There may be a plug covering the hole to make the hole not so visible. If you should have problems fell free to let me know, Thanks Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Posted on Aug 17, 2009
Amana fridge is not cold
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 26, 2011 | Amana ABB1927DE Bottom Freezer...
I have an Amana refrigerator with the freezer on the bottom (Model# AFB2534DEW. About a week or so ago things in the freezer were extra frozen (ice cream was rock solid). Then a few days later our...
you need the defrost heater replaced by the sounds of it.
when u unplugged it you allowed the build up of ice on the evaporator to melt therefore increasing the air flow again.
Regards
Ian
Apr 17, 2011 | Amana AFB2534DE Bottom Freezer French Door...
REFRIGERATOR STOPPED COOLING
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 05, 2010 | Amana AFB2534DE Bottom Freezer French Door...
Amana AFB2534 freezer is regularly getting frost buildup at the back. first 2 times it was so bad that it blocked the vent & prevented cold air from reaching the refrigerator. Freezer just doesn't seem...
This is either of three defrost parts. The timer, heater or defrost limit switch. Most amana's I fix have a bad limit switch which is clipped to the freezer coils directly. Spin your defrost timer till it clicks and check the same frost laden wall to see if the frost starts to steam and melt. If not, unplug the fridge, then try disconnecting the limit switch and join those 2 wires together. Replug and see if the heater starts steaming. If it doesn't it is most likely the timer. The heater is usually the last thing to die, unless your heaters are encased in glass. In which case a quick visual inspection for decay and separation will pinpoint the problem.
Mar 05, 2010 | Amana AFB2534DE Bottom Freezer French Door...
Water dispenser won't work --ice dispenser is fine but no water comes of the water dispenser.
fridge set too cold ? frozen tank or water lines in fridge. set ref warmer for a couple of days
Aug 26, 2009 | Amana AFB2534DE Bottom Freezer French Door...
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Amana AFB2534DE Bottom Freezer French Door Refrigerator Logo
47 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
