Hotpoint aquarius wt540 no power in machine no light at switch
Hotpoint aquarius wt540 no power in machine no light comming on at switch there is power going in from switch
  • Anonymous Mar 30, 2014
    my hotpoint aquarius WT540/IP .when switched on is tripping my power breaker on my fuse box,,i have checked the plug,also the socket,all fine,,but yet it still trips out as soon as i switch the washer on,,can you help please,
  • 6,784 Answers
Hi, check the following trouble spots below. you will find the issue in one or, all the areas stated.
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch/door switch
The washing machine may not function if the lid switch or door switch is defective. The switch is usually located near the door. Replace if found defective.
**If you are getting power to the washer and, step 1 and 2 check out ok, replace the timer control and start switch as well.(You can test the continuity or, resistance level of the Lid switch with a multimeter(ohm).
Posted on Jul 16, 2009
All lights flashing
just fixed 1 of these this morning.....was the main board at rear of machine in bottom corner.........
cheers
Mar 10, 2015 | Hotpoint Aquarius WT540 Front
Does the outer drum on a hotpoint WT540
All outer tubs on most Washing Machines these days are sealed.
Therefore you cannot split the tub to get inside and change the bearings. instead you have to change the whole tub assembly as a complete unit. Not an easy job.
Oct 27, 2014 | Hotpoint Washing Machines
Wt540
how-2-repair.com i found this web site for you
Mar 31, 2014 | Hotpoint Aquarius WD63 Front Load...
Have you checked the door lock switch? If that fails, the control board will light up but wont let you start the machine as it thinks the door is still open.
Nov 08, 2013 | Washing Machines
Hotpoint wt540, reduced creases and extra rinse lights are staying on all the time
1) clean the contacts ribbon with erase pencil and put a little ethylic alcohol.
2) try it 3) if the problem persist the control board is faulty.
God bless you
Oct 11, 2012 | Hotpoint Aquarius WT540 Front
My hotpoint aquarius TCL770 isn't drying clothes
Good evening
There is most likely something wrong with the electricity in the machine.
Kolbrun
Feb 26, 2012 | Hotpoint Aquarius WT540 Front
Hotpoint aquarius wt540 - it has started to malfunction
Most likely a control board failure, you need a service tech to come out.
Oct 27, 2017 | Hotpoint Aquarius WT540 Front
Drive belt came off Hotpoint Aquarius WT540
At each side of the lid there is a small plastic cover. Remove these then take out the screws. Lift the lid at the front and push it back then lift off.
Thankyou for using Fixya.
Jan 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
530 people viewed this question
Top Washing Machines Experts
