Question about Vacuums
Rug brush won't turn. I did get it stuck in a
Rug brush won't turn. I did get it stuck in a carpet edge, but I stopped it immediately. Is there a re-set button, or will it come back on when it cools off?
    Scholar:
  • 78 Answers
Sure...it must, come back to normal, try cleaning the dust pan of it, then reset it..!
thank u
Posted on Jul 17, 2009
I have a rug doctor carpet pro its red. Brushes will turn, hand tool will work but when on carpet won't spray water
Take it to your local vac shop for diagnosis. Sounds like a bad pump, or possibly a bad pump switch. It could also be a stuck diverter valve
Feb 19, 2015 | Carpet Pro Vacuums
Our DC41 is impossible to push on carpet. Is there an adjustment to do? Almost like there is too much suction.
See if the following information can help.
CARPETS OR HARD FLOORS
• The brush bar will always default to 'ON' (spinning) each time you switch the
appliance 'ON' and recline it for cleaning.
• The brush bar will not rotate when the appliance is upright.
• To switch the brush bar 'OFF' (e.g. for delicate rugs and hard floors):
- switch the appliance 'ON'
- recline the appliance
- press the brush bar 'ON/OFF' button - the brush bar will stop spinning.
• The brush bar will automatically stop if it becomes obstructed. See 'Brush bar -
clearing obstructions'.
• Before vacuuming your flooring, rugs and carpets, check the manufacturer's
recommended cleaning instructions.
• Some carpets may fuzz if a rotating brush bar is used when vacuuming. If this
happens, we recommend vacuuming in 'hard floor' mode and consulting with
the flooring manufacturer.
• The brush bar on the appliance may damage some carpet types. If you are
unsure, turn 'OFF' the brush bar.
Dec 31, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
How do I change to different powers
Hi there, it's Jack at Dyson.
DC24's brush bar is powered by its own motor. This means the brush bar can be turned on for carpets and rugs, and off for hard floors or delicate rugs.
To turn off the brush bar, just press the silver brush control switch located next to the red on/off switch. Press it a second time to turn the brush bar back on.
I hope this helps, but if you'd like any further advice you're welcome to contact our experts directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 25, 2014 | Dyson DC24 All Floors Upright Cleaner...
I have a Dyson dc17 I have changed the belt cleaned the brush bar clean the bar motor reset the switch and still when i vacuum the brush bar just stops does not rattle. does not do it on bare floors or...
hooked rugs produce the highest amount of friction opposing the brush rotation, which can over heat the drive motor. try using a height setting that raises the brush so that it barely touches the pile. If this issue has been going on for some time, you may need to replace the drive motor.
Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Brush inside main head doesn't spin, and stops spinning immediately after prompting it to spin. seems like the motor stop turning brush, however when i open main head and cover suction hole for a...
Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 13, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Is the Dyson pulling carpet fibers, not dirt ?
You need to shut the brush roll off. It is ruining your rugs, the dyson has a very aggressive roller and can hurt some types of rugs and carpets.
Aug 17, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Irobot roomba brush only spins on hardwood/tile. brush stops when it hits carpet. motor prob's? fix?
Remove and clean the yellow bearing on each brush, then reinstall them. Run the Roomba and ensure that the brushes do turn on hardwood, then test it again on carpet. If the brushes still stop turning on the rug, call customer support at 1-877-855-8593. They'll be able to determine your warranty status and discuss your options.
Aug 05, 2009 | iRobot Roomba 4300 Robotic Vacuum
Beaters stop when vaccuming rug...didn't when new
I believe you need to change the belt that drives the brushes. When it gets stretched out, it will just spin on the axle of the motor or spin on the brush and smoke.
Jim
Jun 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Hoover Windtunnel carpet level adjustment
The suction is so great that it sucks up your carpet, then nothing works. I get my children to stand on the corners/edges of the rug so that it stays perfectly flat on the floor while I vacuum. Or, you can turn off the brush roller (set it to "hard floor" setting). Or, tip the vacuum cleaner's front up slightly while vacuuming, to reduce suction.
Oct 28, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
71 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
