Question about Gateway MC7801u Notebook
Disable touchpanel I want to disable the touchpanel on the left side. Every time I place my hand, I enable something from that menu and it is a constant interruption
  • 62 Answers
Go into the touch pad properties and set where the buttons are on the pad
Posted on Aug 21, 2009
How do i stop charms keep from constantly popping up?
Sounds like somebody put a nasty virus on your Pc known as Windows 8. Ha just kidding but it is lousy. I run Linux Mint so I don't have to deal with such junk. At the Microsoft Community others are talking about your issue , maybe you can get some answers there. Good Luck.
want to disable the charm screen from popups
Aug 29, 2014 | Acer Aspire 5610-4648 Notebook
Dont know how to switch my touchpad back on when it switches off without rebooting!!
This laptop has a special feature which allows you to double tap the top left hand side of the touch pad, and it will then enable, or disable the touchpad. If you see a orange light on the touchpad, then double tap the light, and it should enable the touchpad again. On a side note, you should be concerned with why the touch pad is disabling itself to begin with!
Jan 07, 2011 | Compaq Presario CQ56-115DX Laptop
Can I disable the pinch-zoom from the mouse pad?
Go to the touchpad icon on the taskbar and go to the pointing device properties . Go to the device settings tab, then click the settings button. On the left hand side there is a menu of items to select, click on pinch zoom and unclick the enable zoom box, press apply and ok. This should solve your problem.
Please let me know whether this works.
Dec 13, 2010 | Toshiba Satellite A665-S6086 Laptop
How to setup or enable wi fi from belkins to laptop wirelessly
  1. Connect the computer to one of the four LAN ports on your router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. Click on "Use as Access Point" on the left-hand side of the opened page.
    Select Enable. This will give you the options to set the IP Address and Subnet mask for the router. These settings should match your existing network settings; by default the IP address will be set to 192.168.2.254 and the Subnet mask will be 255.255.255.0
Alternatively:
1. Click on LAN settings in the left hand menu.
2. When the LAN settings page opens you will make two changes.
Change the IP Address to something such as 192.168.2.47 or you can use 192.168.2.200. As long as the first three sets of numbers match your existing network, you will be fine.
3. Secondly you are going to disable or turn off the DHCP server.
4. Click the Apply Changes button.
Nov 11, 2010 | Belkin (F5D7633UK4A) Wireless Router
The wirelss enable/disable switch will not work, and is curently disabled, can i enable it another way (acer 5570-2067)
1)Go to Start Menu
2)Choose Control Panel
3)Choose Network Adapters or Network and sharing center
4)Right click the wireless adapter (it should say disabled in grey letters beneath the adapter) Vista users will have to choose Manage network connections from the left hand menu before they will be able to see the network adapters.
5)Choose enable
That should do it.
Good Luck
Gill
Sep 24, 2010 | Acer Aspire 5500 5570-2609 Laptop
Cs walked on my laptop. noow cursor pad not working. Help
have a look at the F keys - is possible one of those disables the touch pad
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to claasic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 20, 2010 | Compaq (153515-001) Touch Pad
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
Problem with mouse in my new Dell laptop
Touchpads
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | Dell Inspiron 1420 Laptop
My touchpad has stopped working. Device Manager
Comment back with Make and EXACT model
Mar 24, 2010 | Computers & Internet
Open Questions:
Gateway MC7801u Notebook Logo
109 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
