Question about Nokia 1100
Can i sync my g600 to outlook using bluetooth?
CANNOT USE THE WEBCAM AND BLUETOOTH DEVICE
you might need to syncronise the webcam with the bluetooth device
http://download.cnet.com/%7Bvalue=http://www.download.com/microsoft-activesync/3000-2094_4-10031823.html
Microsoft ActiveSync 4.5 is the latest sync software release for Windows Mobile-based devices. ActiveSync provides a great synchronization experience with Windows-based PCs and Microsoft Outlook right out of the box. ActiveSync acts as the gateway between your Windows-based PC and Windows Mobile-based device, enabling the transfer of Outlook information, Office documents, pictures, music, videos and applications to and from your device. In addition to synchronizing with a desktop PC, ActiveSync can synchronize directly with Microsoft Exchange Server 2003 so that you can keep your e-mail, calendar data, tasks and contact information updated wirelessly when youre away from your PC. ActiveSync 4.5 supports PC sync via USB cable, Bluetooth, or infrared connection.
hope this helps
Jun 03, 2011 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
I want to connect my mobileohone via blue tooth with my pc and I want to synchronice with outlook. How can I do this? Thanks for answer.
You need to purchase a USB 2.0 Bluetooth Wireless Dongle this Converts non Bluetooth PC into Bluetooth enabled.Once you have done that synchronization is easy as either purchasing software for your phone for syncing or copying the contacts / email / calender files to your PC and importing into Outlook. If you tell me what model phone you have I can give you a better sync solution.
May 15, 2011 | Samsung Star GT-S5233 Cell Phone
I want to download photos from samsung G600 and have cable to connect to computer but do not know how to download photos
Try opening (my computer) after pluging in the cable and turning on the samsung. See if the computer picks up the Samsung, if not leave it pluged in and turn off and back on the Samsung. You should see it in (My Computer) along with your hard drive and dvd rom. if not go to the Samsung webpage and see if you can find your G600 and download the software to Sync your computer with the G600. Make sure you have the right OS and hardware to Sync it. If you have Bluetooth you can go to someplace Like Best Buy and get a USB Bluetooth for your computer and transfer pics through wireless buletooth.
Joe
Oct 25, 2009 | Nokia 6233 Cellular Phone
Can I sync my LG VU with Microsoft Outlook? If
Hi, you're right you'll need usb cable however bluetooth can be used as well.The usb cable is supplied with the phone. Vista use the new Windows Contact and Windows Calendar,but you can use MS Outlook if installed and you'll need MS IE v6.
Rate me if helped.Thanks.
Jun 18, 2009 | LG Vu CU920 Cellular Phone
Can receive files via blue tooth on blackberry but how to receive contacts from lg phone
You can send your contacts via Bluetooth, it'll be stored within the Documents folder. Open the vcf file - contact file and select Add to Contacts.
If this option is not available I would recommend sync-ing through Outlook. Put the LG software on to your computer and complete the sync. Then connect your BlackBerry and using the BlackBerry Desktop Manager you should be able to sync your contacts with Outlook.
We hope this helps!
Apr 30, 2009 | RIM BlackBerry 8820 Smartphone
How do I sync with Microsoft Outlook calendar and contacts?
Apr 14, 2009 | LG Vu CU920 Cellular Phone
Ipaq 4100 problem syncronizing with outlook on new laptop
you are now using outlook 2003 , probably cache , this means all the email is on your laptop. when you sync it will sync all the email (thousands). initialise your ppc (back to factory default). set up the sync via usb cable. then sync via bluetooth . then you are fully sync. now setup an auto backup of your email data (daily). if after some time , you have sync problem again , initialise the ppc, restore from backup and you are back to sync (last full backup). try this , you will never need to do it all again.
Regards
David Ng
Sep 23, 2008 | HP iPAQ H4150 Pocket PC
Samsung G600 Sync Problem
Samsung G-600. Got the same problem and used the suggested solution and it worked. Thanks
Oct 23, 2007 | Nokia 1100
Nokia 1100 Logo
50 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
