Question about Garden
Lost compression Would not turn over, when it did it had lost its compression.
  • iwae405 May 11, 2010
    care to mention the model first?
  • kerry littleton May 11, 2010
    no oil in fuel???
    Sniper:
  • 60 Answers
Hello . I don't know what model we talking about but you should have over 100 psi of compression on the cylinder . If not you have to replace the piston rings and maybe the piston . Hope this help
Posted on Aug 29, 2009
Whats wrong when my car looses compression and stalls?
Possibly not lost compression. May not be proper mix of fuel and air. Check the exhaust for blockage.
May 07, 2015 | 2007 Toyota Camry
I have a 2042 and it won't start and turns over faster than it used to?
Seams like you may have lost your compression...Maybe due to timing broken valves,piston etc..Pull you plug or plugs and test for compression...can do simple text placing your thumb over the plug hole and turn the engine over just make sure your plug wires are covered so no shock or buy a compression tester at any of the local auto parts store. Fairly in inexpensuve..good luck....
Mar 04, 2015 | Garden
I have a 2006 350is Lexus that has over heated. It has over heated and won't start back up all it does is turn over
What has happened is you have Warped the Head and lost Compression in the Engine. Without Compression, no Fire due to the Low Compression. Sorry....
Jul 20, 2014 | Cars & Trucks
What could be wrong with an audi A4 2004 that loss compression and doesnt start anymore?
Lost compression? Check that the timing belt has not broke. Is your camshaft still turning?
Nov 11, 2012 | 2004 Audi A4
Car lost power while driving then cut off and will not restart was told its a broken crank shaft has no compression but belt turns and cams turn
Broken cranckshaft will have a knocking noise, did you check the compression, perhaps the cambelt slipped a few notches due to stretching. Check fuel supply.
Jun 25, 2012 | 2001 Nissan Altima
My 2003 sunfire wont start its getting fire and gas and it turns but wont start why
Please consider following matters:
1. Ignition. Blue color fire is the the best ignition power 2. Gas. Check your fuel filter and injections 3. Compression. Combustion chambers should have enough compression to start the engine. Does your car lost its compression? Is the car has blue smoke on exhaust muffler ? Do you need top up oil regularly? All these things show your car has problem with compression.
Nov 26, 2010 | 2003 Pontiac Sunfire
Engine will not start or run,has fuel pressure.and spark
You have lost your compression, need to check compression to make for sure,Your belt may have broke ,does it have a strange sound when you turn it over?
Sep 04, 2009 | Dodge Daytona Cars & Trucks
NO GEARS WORKING
need more info...if you can turn easily ,sounds like you have no compression in engine..pull a plug and test for compression ..you may have washed down cylinder walls with too much fuel and lost compression....if so, you pull all plugs and squirt several sprays of motor oil into each cylinder and turn over to re-build compression........also if you jumped your timing chain, the valves would be open when they should be closed causing no compression, I would need more info on what its doing
Oct 09, 2008 | 1989 Dodge Dakota 2WD
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
