Question about Fujitsu ATI RADEON (64 MB) Graphic Card
We are getting a "garbbled" unreadable screen which goes white. We did a reg clean using cclean.comand it worked for about half a day, we did it again and same results. The is a Fujitsu N3500 Notebook with AtI Radeon x300 graphics card. Does the card need to be replaced? Is it separate or part of the mother board??
  • 3,230 Answers
First of all i suggest you to check the display of your notebook, try plunging a external monitor to your notebook if that works fine means there is some problem with the screen else you need to change the display card of your notebook.
display car is inbuilt in this notebook but you can also use a PCI card.
Good Luck!!
Thanks
Posted on Jul 16, 2009
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Our HP 3015 fax is not sending a readable fax at the receiver's machine. About half the page is readable, and the other half has a series of horizontal lines which makes the balance of the page unreadable....
it only happens when you have something on the scanner
Over time, specks of debris might collect on the scanner glass and white platen, which can
affect performance. Use the following procedure to clean the scanner glass and white platen.
1. Use the power switch to turn off the product, and then unplug the power cord from the electrical socket.
2. Tilt the device control panel forward.
3. Clean the glass strip and the white platen with a soft cloth or sponge that has been moistened with nonabrasive glass cleaner.
hope it solve the problem, if so rate the solution
Nov 22, 2010 | HP Office Equipment & Supplies
The note book works very slow?
Clean your machine using the Windows clean up utility in the System tools folder or get the free utillity called CClean (google it)
When you get CClean, use the top two tools on the left hand side. Id suggest not loading the Yahoo tool bar during setup.
Get Comodo Reg Cleaner ... run it and remove everything it says to remove
Run the Add/Remove software - take the windows stuff you dont use out.
Find out what runs at start up and stop all the stuff you dont REGULARLY use. Ask Windows Help about startup.
Get Spy Bot - Search and destroy from www.pcworld.com Dont get a paid look a like of this - get the free version. When it runs, it may take several hours to scour your computer. There are some nifty tools in this program also ... one in the ie tweaks allows you to pur your name (or what ever) in Internet Explorer - real nifty.
Defragment your drive using windows defragmenter. Alternatively get Defraggler from the CClean people
You have the windows programs ... the others of which I speak are free to download and use
That should speed up your Acer.
Oct 19, 2009 | Acer Aspire 5050-3242 Notebook
Unable to pull up google maps
Clean your computer ... use CClean then defrag your drive - try again
let me know if this improves your performance
Oct 01, 2009 | Acer Aspire One PC Notebook
Slow connection to internet, sometimes cannot get tnternet sky customer
This is not a monitor issue to my way of thinking.
Look at your modem, your router, and your ISP. Do you have cable? Have you spoken with them? Reset in this order - everything off - modem on wait 60 seconds - router on wait 60 seconds - computer on - boot - try.
To more mundane things, do you perform regular maintenance on your computer? You collect many files every day as you spend time on the WWW. They must be cleaned out from time to time.
I regularly use CClean (a free download) to do this. I also use the Reg cleaner in this program. (google it)
I also use Spybot - search and destroy - available at PC World.com
I also use Comodo Reg Cleaner - another teriffic cleaner.
I would suggest you get these programs - run them, reboot and then defragment your machine.
It MAY not help your connection speed but it will definitely speed up your computer.
I hope you find this suggestion hjelpful
a
Sep 28, 2009 | Samsung SyncMaster 731B 17" LCD Monitor
Screen Goes Black When Game Is Inserted
Your laser could be bad, that is my idea for the situation. Your laser probably loads to a certain point and then just stops for some reason. You can try adjusting the potentiometers up 10 percent if your technologically advanced or try and replace the whole laser/drive.
Nov 21, 2008 | Microsoft Xbox 360 Console
Cclean
http://www.ccleaner.com/download
its a setup for registry cleaning
Sep 27, 2008 | Microsoft Windows XP Home Edition
My Toshiba laotp's screen goes half blank help!!
Well try to boot into the safe mode.hit F8 on the startup and see if you get the same acreen.If its working fine in safe mode than you need to reinstall the video driver and that should resolve the issue.If it is still not working try connecting a external moniter.If you get the same display on the external moniter than its an issue with the video card and if you get a normal display on that than its an issue with the Laptop screen and you would ahve to get either of thses replaced by contacting the manufacturer.
Hope this helps!
Sep 17, 2007 | Toshiba (225EXTR5)
White Screen / Black Screen (Oreo Condition)
try taking ur memory card out i had a simmilar problem my phone was just sitting on the desk and just randomly started flashing black and white it wouldnt let me turn it off i couldnt use it to make calls then after an hour of playing with it i took the memory card out and it worked normally again the only problem is now i cant use a memory card so.... can any1 help me??
Dec 26, 2006 | Motorola Mobility E815
Computers & Internet Logo
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
