Question about Sony DSC-T70 Digital Camera
Battery cover for BLACK Sony T70 is broken.
Hi.
I need the replacement part for the battery cover on a black Sony T70.
The small grey piece, which is the lock, has snapped.
I'm in the UK.
Does anyone have any ideas where I can get the part and of the approximate cost of the part?
Thanks!
  • 10,594 Answers
Battery Compartment with lock of DSC-T70 is single part and can be order under following part number..
X-2186-609-1 ASSY, BTH (B) (BLACK)
I'm afraid I do not have info about parts shops in UK so please check with nearest Sony Service Center for that part.
Thanks.
Below image of DSC-T70 will give you an idea for required part..
Posted on Jul 16, 2009
Hi, I have a Sony DSC T70. The battery door for the camera doesnt close now as the latch just came sliding out and I am not able to fix it.... Do i have to replace the whole battery door for it and if...
Hi, With a battery door like that you can tape it shut, while not the most visually appeasing fix it is the cheapest. Your other option is to order a battery door for the camera, http://www.ownta.com/sony-dsc-t70-camera-repairing-battery-door-battery-cover-replacement.html has it for $45, or you can contact Sony and order one directly from him. The only thing I'll caution you about with replacing the battery door is that you do have to disassemble the entire camera to install it.
May 12, 2011 | Cameras
E:9101 shwos on the screen on DSC-T70 sony cybershot
Follow these steps:
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
May 12, 2011 | Sony Cyber-shot DSC-T70 Digital Camera
Panel is dark and won't light. Camer still
before trying anything else suggest you try a new battery. make sure it is manufacturer recommended battery because it does make a difference.
http://www.teleplancamerarepair.com/Sony_Cyber-shot_DSC-T70 will repair it for you and give it a good cleaning too for one third of the price of a new camera
Jul 13, 2010 | Sony Cyber-shot DSC-T70 Digital Camera
Broken battery cover on pink sony cybershot dsc-t70 replacement?
I know for a fact that this company, Teleplan Camera Repair, replaces battery covers. They would have your part for you.
Apr 09, 2010 | Sony DSC-T70 Digital Camera
I need to replace the battery on a Genie GICT-390 garage door opener. How do I open the case?
If its a lighter grey colored intellicode remote: There should be a small slot on the side of the remote. Use a coin such as a dime or a penny, stick it in the slot and twist. The remote should split in half and you'll see the coin-shaped battery. After you replace the battery, you can snap the 2 pieces of the remote back together.
If its a dark grey/black intellicode remote: The back cover should partially flip open to reveal the battery. This remote takes a 12volt N-size battery.
If its a keypad remote you are referring to: The bottom half of the keypad's face should slide straight down to reveal the battery (you should see and arrow and some thumb grips). All Genie keypads take 9volt batteries. Source(s): I am a genie technician
Oct 24, 2009 | Genie Company IntelliCode GICT390-1BL...
Change battery in GICT390 3 button remote
Oct 10, 2009 | Genie Company IntelliCode GICT390-1BL...
Camera door thats holds battery small grey latch is broken
Try partstore.com they might be able to solve your problem. Also look at the latch and determine if it is attached to the front of the camera case or the back of the camers casing I am assuming it is attached to the back then you might consider caling HP back and ordering the Back or Front cover Assembly. Small pieces like this usually don't come by themselves you have to order an assembly, so when when u call for parts ask for Back cover assembly or front cover assembly, which ever it is attached to or apart of. Asking for a perticular piece they will not usually know what you need. You have to talk to them in technical terms.. Hope this helps you out...
Sep 21, 2009 | HP R967 Digital Camera
Sony DSC-T70 CyberShot memory/battery cover broken
Yes, why not..
Here is silver color battery compartment part number of DSC-T70
X21866081 ASSY BTH (S)
It is available in Part Store.
Please rate this and previous solution with 4 blue diamonds if you found them correct.
Dec 06, 2008 | Sony DSC-T70 Digital Camera
Assuming that your Sony DSC-t70 has black color cabinet then you need battery Compartment with following part number...
IMPORTANT (If camera has different color cabinet, let me know to provide you appropriate part number)
Above said part is available in Part Store on $33.42
Sony Dsc T-70 Digital Camera
Let me know cabinet color of your DSC-T70 to provide you battery compartment information because this camera is in 4 colors, Silver, Black, White and Pink and has difference in part numbers.
Dec 02, 2008 | Sony DSC-T70 Digital Camera
Sony DSC-T70 Digital Camera Logo
682 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
