Question about Kenmore 60172 Electric Commercial Dryer
Kenmore 70 series model # 96573220
Buzzer won't stop after clothing cycle and the start button won't start the dryer, the only way to stop the buzzer is to open the door
  • 1 more comment
  • long08 Apr 21, 2008
    My dryer (Kenmore 70) won't stop... will run through cycles none stop if dryer door is shut, clothes do dry
  • Anonymous Mar 18, 2014
    Brand new Whirlpool dryer (installed today) WED4800BQ model. Buzzer doesn't sound.
  • Anonymous Mar 29, 2014
    buzzer won't stop buzzing sometimes
  • 240 Answers
Sounds like the push to start switch has gone bad. Not to expensive to fix, and pretty easy to do as well. You can remove the rear of the console, remove the push to start switch (lift the tab, then turn to unlock) and replace. Be sure to mark your wires so they go back in the right order. Jim
Posted on Nov 18, 2007
1st time to your site and was thrilled to see some one had the exact problem with a suggested solution. Hopefully, hubby can fix it.
Posted on Jul 30, 2008
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
I have a Kenmore dryer 70 series. The buzzer won't turn off once the cycle is finished until I open the door. If I move the timer into the middle of the cycle and close the dryer, it will start again w/o...
It sounds like you have a faulty switch. The switch located behind the start button controls both the on/off setting and the buzzer. You can either replace this switch (which will likely take care of both problems) or you can take it apart and adjust the contacts. You can test them with a multimeter before and after to make sure you've got them adjusted properly.
Aug 21, 2010 | Kenmore 62602 Electric Dryer
Kenmore 70 series dryer leaving brown marks
you can get the parts direct from www3.sears.com and to replace it you pop up the top, take 2 screws out holding front panel onto cabinet and take off, take belt loose from idler and motor and slide drum out ,, go back same way / thanks
Jan 13, 2009 | Dryers
Kenmoore 70 series Buzzer will not stop
buzzer is built -in the timer you all should replace it if you really want it solved they have done their work over the years. It's not something you can just go in and unplug or cut sorry. Good Luck. Post your make and model numbers next time please.
Dec 19, 2008 | Kenmore 60172 Electric Commercial Dryer
Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
  • the buzzer is located under the control panel.
  • you can unplug it.
  • unplug the dryer or turn the breaker off first
  • then take out the 2 screws on both sides of the control panel
  • bull it forward toward you and unhook it from the case
  • you should see the buzzer with two wires going to it
  • only need to disconnect one.
  •  just make sure you wrap the bare wire connector with electrical tape to keep it from touching metal.
Jun 28, 2008 | Kenmore 60172 Electric Commercial Dryer
Kenmore 60172 Electric Commercial Dryer Logo
841 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
