Question about GE 19TVR62 19 in. TV/VCR Combo
Cable connection broke off. Would like to order new part where the cable connects to
  • GE Master
  • 5,138 Answers
IF connectors for turners,call 1-800-223-3205 this is Electronix Parts ,also make sure your turner is ok other wise replace turner!
Posted on Nov 19, 2007
Cable connection in TV broke off
That part is soldered into the TV circuitry. Chances are that a TV repair professional will need to open it up unless you know someone that knows how to desolate and solder in a new plug. If the circuit board is damaged, then you will have to source a new part.
Oct 20, 2014 | Seiki 32" LED TV - SE321FB
Cable connection broke off bake of unit
if i was u id take to expert as i have had same problem once found cable was incased inside box very had to open so took to repair shop didnt cost alot
Nov 27, 2012 | Panasonic TH-42PX60U Television
Antenna in port connection broke off the tv
You can purchase the whole main pcb for the tv, but this would be costly with arts and abor. You could order just the part you broke called the Tuner but, you would need to know how to solder to take off the old and put on the new one which is time consuming. The cheapest and easiest way is to if you do not have cable or sattelite and just have an over the air antenna, get you a converter bx with the composite outputs "red,yellow,white" and connect that to your tv. Thats the cheapest and simplest work-around fix. Good luck!
Jun 29, 2012 | Sylvania Televison & Video
The spring on my auger clutch cable broke. Where does this spring connect too? I ordered a new cable and spring but I can't locate where the spring connects too. I have a model 317-611D000 snowblower
my auger cable is not working the auger so i adjusted it and it was to tight and the plastic holder that holds the cables poped off and broke,now the cable i adjust it and nothing happens,cable is all hooked up and seems ok but it will not work right,but the auger spins with out the cable,wondering if it needs a new auger cable
Dec 26, 2010 | Mtd Genuine 9460897 Snow Blower Auger...
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Cable connecter broke off?
It would probably cost more to have someone fix it than just replace it.If you or someone you know can use a solder iron you might get lucky and resolder conections, but most times its too hard to get at the circuit board to affect repairs and the connector usually gets mangled so bad it won't fit right anymore. Or you can try to avoid using this connection and use a different input. But you would need either a cable/satellite box or vcr (with the same kind of connection that broke on TV) and change the input used on the tv to the new connection such as 3 wire AV connection (with the yellow,red and white wires)
Apr 26, 2009 | Sharp 25H-M60 TV
yep if you can desolder the tuner with solder braid then put new tuner in resolder it thats it
bc
Feb 02, 2009 | RCA F32650 32" TV
Cable connection in back of tv broke.
part name -tuner -u can buy from electronics spare part market
Dec 26, 2008 | GE 27GT271 TV
Connection cable for the to moniters
This is custom cable, I called a company that sells AV cable, they say they could make a custom one for around $35.
Jun 27, 2008 | Durabrand Portable DVD
Dell dimension monitor output broke away from motherboard and now i get no output to monitor to "wake it up", nevermind being able to see anything on it. As soon as i unplug the monitor cable from the pin...
Depending on how much it has broke away, you may be able to resolder it back on, or find someone who can. Other than that it will be a new board, I suspect.
It seems at least a few connections are OK, so probably worth a try, before scrapping it.
Jan 16, 2008 | Dell (W2562) Motherboard
GE 19TVR62 19 in. TV/VCR Combo Logo
123 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
