Question about Philips 42PF9630A 42 in. Plasma Television
Menu Screen Keeps Coming up on the screen
My problem is pretty simple. The menu screen for my 42" Philips plasma TV keeps popping up on the screen. I press the menu button on the remote to exit, but the menu pops right back up after a couple seconds. I've tried unplugging the TV for the night hoping it would "reboot" when plugged back in.....didn't work. I thought maybe it was a problem in the remote, so I took the batteries out......still kept popping up. I'm out of ideas! HELP!
  • brian_pop Jul 17, 2009
    I called Philips Tech support and they said that all it needed was a software update! Go to www.philips.com/support, click on software/drivers, then download the update to an COMPLETELY EMPTY memory stick. It's going to be a zipped file, so after the download, unzip it on the memory stick and remove the stick from the computer. Make sure the TV is OFF and insert the memory stick into the USB port. Turn the TV on and the update should start automatically. It didn't work for me the first time, it took me a couple times repeating the whole process, but it finally worked and my problem was solved!!
  • 304 Answers
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Posted on Jul 17, 2009
4 Suggested Answers
  • 4 Answers
SOURCE: 42" philips plasma, black screen and flashing red light
I did the same, replaced two bulging capacitors...cost me 2.00 for the capacitors and $20 for the desoldering/soldering tools. First time doing anything close to this with any electronics...tv works great now.
Posted on Dec 31, 2009
SOURCE: Philips 42 wont turn on
I am having this same problem. I have "fixed" this problem twice by replacing 2 failed capacitors inside. The fix is pretty easy and the cost of the replacement parts is about $2.50. Unfortunately, the fix doesn't last. The first time, the TV worked again for about 6 months, but the 2nd time, when I replaced with higher grade capacitors, I only got another 2 weeks out of the TV. I think it's time to cut my losses and get a new set. Repair costs were estimated at $600. ...just not worth it.
Posted on Jul 11, 2010
19ken55
  • 426 Answers
SOURCE: my philips 42 plasma wont exit the menu
try turning it off and unplug then go again
Posted on Jan 23, 2011
THE MENU KEEPS POPPING UP ON THE SCREEN CONTINOUSLY ON MY 42 INCH
I had an LG 37" LCD that did this to me. Turned out to be bad solder joints on the side button board. Just reflowed and it starting working fine.
But now that I think about, I had another set do the same thing, only it wasn't the button board. I had to upgrade the TV's firmware via the USB service port. Just needed a USB flash drive and downloaded the firmware from the mfg's website. There were easy to follow instructions there too!
Nov 29, 2009 | HP PL4260N 42 in. Plasma HDTV
Menu keeps popping up
check remote faulty batteries/take them out see if it stops doing it also depress menu button on tv might be stuck
Nov 10, 2009 | Philips 42PF9630A 42 in. Plasma Television
My Phillips Plasma tv MENU pops up unasked and obscures screen.
there is a soft ware upgrade for that problem on there web site you can down load it to a thumb drive and upgrade your set
Oct 31, 2009 | Philips 32PF7320A 32 in. LCD Television
Menu screen
It could be dirt/dust has accumulated behind the buttons causing a false contact so it looks like a ghost is operating your tv making things appear and disappear.If this isn not the problem then there is a faulty component on the board where the buttons are located. If you are able to do the cleaning of the buttons yourself use a cleaner that de-greases as wel and make sure everything is bone dry before re-assembly. If not find a competant technician. Hope this helps.
Sep 01, 2008 | Philips 42PF9630A 42 in. Plasma Television
Menu screen keeps coming on
I hate to call Philips liars but the logic of the situation speaks for itself. If it was a software fault then your tv would have done this from day one and I bet it just started to do it out of the blue. I think it could be a faulty component on the board where the buttons are located. Hope this helps.
Aug 27, 2008 | Philips 42PF9630A 42 in. Plasma Television
Menu screen won't go away but i have sound
I am having the same problem too~ The menu screen keeps coming up!
Aug 24, 2008 | Philips 42PF9630A 42 in. Plasma Television
Menu 42PF9630A 42
go to www.ceusasupport.philips.com and upgrade your televisions software to the latest version. this is a very common issue.
Jan 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF9630A 42 in. Plasma Television Logo
1,745 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
