Question about Samsung ML2251N Laser Printer
Paper jamed, emeshed in paper roller which is broken. What is this part called and where can I get it.
    Champion:
  • 220 Answers
Part is called fuser,call any samsung dealer
Posted on Jul 23, 2009
I have a MINOLTA CSPRO EP6001 and the paper is jaming in the fuser area need help fast!
Replace the upper/lower fuser roller? Check the pick fingers on both rollers any of the broken? By pass front door is the fuser rollers moving ?
Apr 22, 2016 | Minolta Office Equipment & Supplies
Why does ir3300 canon photocopier show paper jam between the lower tray and right cover yet no papers jamed and even else where, what could be this?
these also can occure if the paper from the cassette isn't picked up or if the paper pass the cassette and exits but sensor flapper has slow response.
As first step I would recommend to change the paper pick-up, feed and separation rollers in cassette.
Remove the cassette out, look inside, on inner right side you will see 3 tire rollers. Each roller has nose with plastic hinge. To remove him you need to push hinge on the nose and pull out the rooler to a side.
If they are worn out they will be smooth.
You can remove the rollers from the tray that works and put it into troubled one for test. If the paper jam doesn't occuress you are sure that you need new rollers.
If not I recommend to call service.Because, also the problem can be in paper lifting claw, broken gears,...
For service manual you can contact me on emma.servis@gmail.com
Hope that helps!
Sep 01, 2011 | Canon Office Equipment & Supplies
Priport jp 5000 thinks it's jamed after each
Look for the sensors which are mounted a little before the roller as the paper is fed the sensor will detect -- therby called INDETECT sensors.
So it can be due to misaligment of a failure and must be checked with a multimeter.
Aug 31, 2011 | Office Equipment & Supplies
I have alot of jamed paper in my Epson Stylus Photo RX595 printer. I also have tore paper jamed in the printer per following the directions in the Epson manual. Please help.
ithink problem come from paper roller, maybe the paper roller is broken, or gear box of the roller is nor connect properly, contact srvice center to fix it
Dec 03, 2010 | Epson Stylus Photo RX595 Series
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
Paper is getting jamed as it attempts to enter the finishing unit.
Hello sir; First, check out the paper path have anything stuck inside, otherwise go to replace paper exit senser on the machine or paper entrace senser on the finisher ( depend where got paper jam).
Oct 09, 2009 | Toshiba e-Studio 45 Black and White Copier
Has paper jamed in machine can not acess paper though any of the openings can see the paper though front bay it is jamed in between front rollers.
Not seeing this machine, if the drum can be taken out this can help.
If nothing can be taken out, be very careful when attempting to pull the paper out. Paper can scratch the surface of the drum and can pull stripper fingers out of place. Also there may be mylar fingers in place that may be bent or broken off causing further jams.
Using long pliers might work.
More description of this area needs to be given in order to pull this paper out. There might be other internal parts that need to be checked in order to keep this type of jam to occur again.
If al else fails place a service call by a copier service representative.
Oct 07, 2009 | Canon Office Equipment & Supplies
The rollers, where the paper jam is on the inside. The paper will feed from the both tray and from the side feed but will jam just before these black rollers.
It could be one of a few things... You may have a small piece of paper jamed in the fixing unit or you may have a broken driver gear for the fusing unit.. If you do not see the fixing rollers turning and it is making a noise, the gear most likely is broken.
Aug 16, 2009 | Office Equipment & Supplies
Panasonic kx-fp 342 papaer jam
paper jam or missfeed always due tothe following:-
1-malefunction of paper feeding system due to broken gears belt chain please check smoth mechnical movement and apply light grease in gears and change any broken part.
2-something is blocking the paper path (staplers-pins)droped inside.
3-malefunction of paper detection micoswitch please confirm free operation for the lever in mechnical one and clean of dust and dirt from optical one,
Mar 06, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
Samsung ML2251N Laser Printer Logo
124 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
