Question about Kenmore Elite Oasis ST 6806 Electric Dryer
The Dryer will only stay on if I hold the start button down.
  • 6,784 Answers
HI, this will occur if the start button circuit is damaged. it is unable to hold the current at this time. this will cause the switch to fail, as in this case. replacing the start switch will fix this issue.
Posted on Jul 16, 2009
jsrock516
  • 5911 Answers
SOURCE: Will not stay on
Your problem is usually associated with the small micro-computer board located inside the control panel. You can access the inside of the control panel by following these simple steps: 1. Unplug machine. 2. Remove the end caps of the console. This can be done by inserting a flat blade screw driver into a groove at the top of each end cap on the back of the console and lifting up slightly. The end cap should just pop loose. 3. After the end caps are out of the way, loosen the two philips screws on each side of the console. 4. Once loosened, the console should flip back by pulling slightly towards you, then up. Inspect the control board for burned components. Even if you don't see anything obvious,the board could still be bad. I still recommend replacing it. I have repaired this problem before and it had nothing to do with the start switch. Good luck. I hope this helps you.
Posted on May 13, 2007
agitateme
  • 88 Answers
SOURCE: Dryer wont stay running
Either the motor relay, or if this is an evenheat dryer, the evenheat control board could be bad.
Posted on Jan 17, 2008
codfish124
  • 36 Answers
SOURCE: Whirlpool dryer will not stay on, no heat, and timer acts weird
sounds like the motor or the even heat board is out i would say the even heat board is more likely
Posted on Dec 09, 2008
  • 686 Answers
SOURCE: Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Posted on Apr 18, 2009
maddogsteve1
  • 18 Answers
SOURCE: dryer won't stay on unless I hold the start button down. When I let go of the start button, it stops.
most likely the evenheat board is bad, but it could be the motor relay, get under the console and check the trouble shooting wiring diagram. there are several checks you can do to narrow it down.
Posted on May 25, 2009
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Dryer won't stay running without holding down the start button
It may be the centrifugal switch on the motor. The push button starts the motor and as the motor spins up to speed the centrifugal switch closes to keep the motor running. Hope this helps.
Jan 02, 2014 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
My Kenmore 80 series dryer won't stay on unless I
Aha!
You are going to make me guess!
I am guessing you have to hold the start button down.
So.
Try a new start button first.
If that does not fix it, replace the timer/control unit.
God bless your efforts.
Jan 05, 2018 | Kenmore Washing Machines
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
We have to hold the start button down when for
if you have to hold down the start button to keep it running then the motor is shot-mike
Jan 29, 2010 | Kenmore 63952 Electric Dryer
Dryer will not stay on after pushing start button
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Dec 21, 2009 | Kenmore 63942 Dryer
My dryer will not stay on unless u hold it thw
Start devise on motor is defective, replace motor...... call repair tech
Oct 17, 2009 | Hotpoint NBXR463EBWW Electric Dryer
Dryer won't stay on unless I hold the start button down. When I let go of the start button, it stops.
May 24, 2009 | Dryers
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Kenmore Elite Oasis ST 6806 Electric Dryer Logo
53 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
