Question about Cell Phones
I called virgin mobile because my new phone that i just got wont activate what do i do they told me that they cant help me call back tom
Want to activate virgin phone
YOU CAN CONTACT VIRGIN MOBILE (1-888-322-1122) AND THEY CAN ASSIST YOU WITH THE ACTIVATION. WHEN YOU CALL, HAVE THE PHONE OFF AND REMOVE THE BATTERY, YOU MAY NEED TO READ THE NUMBERS LOCATED UNDER WHERE THE BATTERY SITS.
Jul 17, 2014 | LG Optimus V For Virgin Mobile
Sprint customer service
try calling again about your registered cricket phone number and ask them how to manage your account so that you can change you number.
Mar 15, 2017 | Cell Phones
How to reset my virgin mobile LG Flare?
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 27, 2012 | LG Flare Cellular Phone
The top up code on the virgin mobile card won't activate my phone what do i do?
you have to get a seperate phone and call customer service and set it up. Or go online @ virginmobileusa.com and activate.
If you would, send me a kickback! :D
email: jvandiver@boysranchisd.org
Kickback code: hTvsPJQD
Hope it Helps!
Jan 11, 2010 | Alcatel Virgin Mobile ?£30 Text Cellular...
Just gone from virgin to sky and was told i could use my old e.mail address but nothing can not get my e.mails virgin said that now i have switched i have no access apart from ringing sky and being on...
NO! Nio if you had a virgin address tom@virgin.com or whatever. once you switch to another carrier your emails are rejected back to the sender until you advise them of your new address Tom@sky.com or whatever.
If your addres was like Tom@hotmail.com then it doesn't matter what carrier you have as you are dealing with webmail that can be collected by any new carrier via an email client like Express or your choice of email clients.
Please rate my help++++Thanks for using FIXYA
Nov 24, 2009 | Dell Inspiron 6000 Notebook
Samsung virgin mobile pay as you go cell
You need to have the phone activated again through your service provider.
Jun 22, 2009 | Samsung Cell Phones
Wild card virgin mobile unlock
Give Virgin Mobile a call. They should be able to unlock the phone. If they can't, try taking it to another provider like Altell. They may be able to unlock the phone since it's technically an LG phone that they too provide.
If those two options don't work, good luck getting the phone working.
Sep 12, 2008 | Kyocera wild card Cellular Phone
Mxit v 5.6
PHONE SUPPORT
Some phones are not compatible with the MXit application. Don't stress, yours is most probably supported. If you want to double check however, simply click on the relevant link to the left:
(Do not know your mobile make? Have a look its battery, it's usually written there!)
We are constantly expanding our service; if you could not find your phone on this list, don't worry, it is likely to be added soon...
DOWNLOAD
Downloading MXit from our WAP-site:
Jargon buster: A WAP-site is an internet website customized to be viewed on your phone.
  1. On your mobile, go to 'services' (globe icon).
  2. Create a new bookmark (www.mxit.com/wap) and save it.
  3. Select this bookmark, then select then 'go to'.
  4. You should be welcomed to the MXit WAP portal at this stage.
  5. Check that your mobile manufacturer and model has been detected correctly.
  6. Open, accept and download!
  7. Start chatting
CONNECTIVITY
Setting up GPRS/3G
Get connected via your service provider's service menu; just follow the simple instructions below:
(It helps to know your mobile's manufacturer and model. Oh and remember, you only have 2 minutes to complete these steps, don't ask us why!)
Vodacom:
  1. On your mobile, dial *111#
  2. Select option 5 (phone settings) from the menu that follows. (Answer -> 5 -> send)
  3. Select option 1 to choose your mobile make and model from a list, or options 2 to have Vodacom identify the phone for you.
  4. In both cases, simply follow the steps provided to get the WAP settings sent to your phone.
  5. Connection settings will be sent to your phone; save these settings.
  6. If any of the above mentioned steps fail, simply retry.
  7. Still having trouble? Call Vodacom's call centre on 111 from your Vodacom cellphone or 082 111 from another phone. Alternatively visit a Vodacom outlet near you.
(GPRS/3G can only be activated by the person in whose name the contract was taken out, so some of you might have to get mom or dad's help on this one. Good luck!)
Cell C
  1. On your mobile, dial *147#
  2. Connection settings will be sent to your phone; save these settings. If a password is requested enter 0000
  3. If any of the above mentioned steps fail, simply retry.
Still having trouble? Call Cell C's call centre on 140 or visit a Cell C outlet near you. (GPRS/3G can only be activated by the person in whose name the contract was taken out, so some of you might have to get mom or dad's help on this one. Good luck!)
MTN
  1. On your mobile, dial *123#
  2. Select option 1 (phone setup) from the menu that follows. (Answer -> 1 -> send)
  3. Select option 3 (WAP).
  4. Connection settings will be sent to your phone; save these settings.
  5. If any of the above mentioned steps fail, simply retry.
Still having trouble? Call MTN's call centre; dial 808 (contract) or 173 (pay as you go) from your mobile phone. Alternatively, visit an MTN outlet near you. (GPRS/3G can only be activated by the person in whose name the contract was taken out, so some of you might have to get mom or dad's help on this one. Good luck!)
Virgin Mobile
  1. When you first insert your Virgin Mobile SIM into your mobile you'll receive an SMS asking you if you would like to accept Virgin Settings.
  2. If you reply YES, your settings for MMS and WAP can be automatically downloaded and installed on your mobile.
  3. Do the following to manually request MMS and WAP settings:
  4. Go to the 'Virgin Mobile' menu which you will find on either the main menu or applications menu of your mobile.
  5. Select 'Virgin Settings' and reply YES when asked if you'd like to download them.
Still having trouble? Call Virgin Mobile's call centre on 123 or visit a Virgin Mobile outlet near you. (GPRS/3G can only be activated by the person in whose name the contract was taken out, so some of you might have to get mom or dad's help on this one. Good luck!)
Apr 04, 2008 | Samsung SGH-E370 Cellular Phone
Unlocking my virgin mobile wildcard
if you buy any virgin mobile phone the lock code is always the last 4 digits of your cell number if you buy it used from someone then you have to either get the last for digits of their number or take it in to virgin mobile and have then change it for you
Feb 19, 2008 | Cell Phones
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
