Question about Brother HL-2040 Laser Printer
Magenta toner keeps marking low although replaced. How do I fix?
    Brigadier General:
  • 4,088 Answers
Are you installing a refilled cartridge? Some printers have a cute detection scheme that blocks the use of refilled cartridges.
Posted on Jul 16, 2009
How do i fix error code C7103
you need to replace the magenta developer unit
Sep 03, 2015 | Kyocera Taskalfa 250ci Color Copier...
My Ricoh CL7000 is saying add toner magenta. But there is plenty of magenta in the cartridge. I've added toner and cleaned out everywhere I can get to. Any suggestions?
It could be a clog in the toner tube, but the most likely (and easiest to fix) problem is the magenta DV unit. Replace the magenta DV unit, turn the machine off and back on, and if it still says add magenta toner open and close the toner cover so that it can load toner, then your problem should be gone.
Nov 08, 2010 | Ricoh Aficio CL7000 Laser Printer
I have a CLX-3160FN Printer and it says that my Magenta Toner level is low How can I fix that?
Have you tried putting a shim under it to make it higher?
Seriously...If the toner is low, you have to buy a new toner cartridge to replace the on that's low. No ink toner = no print.
Visit Staples, Best Buy, etc. to buy a new toner cartridge.
Nov 12, 2009 | Samsung CLX 3160fn All-In-One Printer
The red is not printing
At a guess you are using recycled toners? If the recycler has not worked out the refilling procedure properly, the problem you experienced with the exploding Cyan toner is common. It is possible in the act of blowing out the loose cyan toner your have used to much air pressure, possibly blowing toner into the laser beam units, or damaging the toner sensor unit for magenta.
A diagnostic inspection, by a technician would be suggested.
Cheers: DeJudge
Dec 30, 2008 | HP Color LaserJet 2600n Printer
Cyan toner does not rotate to front to be change
um... Cyan is blue isn't it?
Magenta Pink,
Yellow = Yellow and
Black = black.
Oct 02, 2008 | Dell 3010cn Laser Printer
Keep Getting Error Message "(Colour) Toner Not Installed"
I think in the menu you have to select replace cartride.. then new or same with new toner...
each toner cartridge has connections and you must make sure all are tight... or you get alot of errors.
Sep 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Magenta backgrounding
If the magenta is low the waste bin may be full and that may be causing the problem. If this is the case you need to change the toner. You can try calibrating the printer. You may have to do this 3 times in a row for it to make a difference.
Press Select-check mark button
Use arrows to go to Print Quality
Use arrows to go to Calibrate Color
Use arrows to go to Calibrate Now
Press Select to Confirm Calibrate Now
Jul 31, 2008 | HP Color LaserJet 2600n Printer
HP 8500 Laser Printer
Did you pull the strip on the Magenta toner when you loaded it into the unit?
Jun 30, 2008 | HP LaserJet 8500 Color Printer
Minolta CMS magicolor printer 2300W
there should be a light flashing on the printer. try pressing the button nearest to it to see if that will move the print head out in order that you can replace the cartridge
Jul 18, 2007 | HP Printer Cartridges (Complete List): ,...
Samsung CLP-550 - magenta bands
I have the same problem. Any solution?
Dec 19, 2006 | Samsung CLP-500 Laser Printer
Brother HL-2040 Laser Printer Logo
124 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
