Question about Maytag EPIC MFW9700S Front Load Washer
How to remove the greasy black stuff on the front load door gaskets.
    Brigadier General:
  • 4,088 Answers
Try rubbing alcohol if soapy hot water doesn't help.
Posted on Jul 16, 2009
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
Have black oily film appearing thru out the
I have had a similar problem on a Bosch. Don't know where it comes from, except to say the bottom door gasket appeared to be melting for some reason. I replaced it with a new one, and no signs of melting after about 3 months.
I was able to clean the black smudge from various parts of the dishwasher using Berryman's Chemtool, a carburetor cleaner available at the auto parts store. Use in a well ventilated area. Am certain naptha or other cleaner would work as well, but again, use sparingly and with plenty of ventilation. Rubbing alcohol would not cut the stuff.
Let me know what you find.
Dec 16, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
My 2 year lold front load GE washing machine has developed a lot of mould in the rubber gasket on the front of the machine. I have tried to bleach it but the mould remains. It causes the cloths to have...
on my lg, there are two small drain holes in the folds of the gasket that got plugged up with lint and stuff, unplug them if you have them. also i leave the door open after wash to let it dry out
Jul 24, 2009 | GE WBVH6240F Front Load Washer
Mold build up around ribber gasket . Heavy, black and hard
Front load washers are notorious for developing mold/mildew to build up because they retain a lot of moisture in the round gasket the door closes into. Wash it down with a 50:50 soulution of bleach and water. You may have to use a brush on the "hard" stuff. Occasionally, run a quick load with no clothes and just bleach through a complete cycle in the washer. After a heavy day's washinh, leave the door open a little to help dry it ou.
May 28, 2009 | Washing Machines
Broken electronic connector on washing machine
seawolrf your going to have to do a little work...open the door now looking at the washer i want you to take a knife or screw driver and take that gasket off right next to the door switch,,the black gasket is glued ,,yes glued pull it up..only by door switch..now remove door switch screws (2) now replace that connection...onthejob
Jan 27, 2009 | Frigidaire FTF530FS Front Load Washer
Lgwm2277h front door problem
The latch on the door had to be change
Sep 16, 2008 | LG WM-2277HW Front Load Washer
Black stuff in the bottom of the dishwasher
That black or gray stuff you're talking about is actually a combination of old food particles and soap deposits. The stuff builds up in the corners of the lower front areas of the tub and right under the inside of the door where it closes over the tub front. These areas can develop "scungy" deposits because these are areas that the dishwasher doesn't always clean and/or water remains pooled. A little routine cleaning about once a week around the bottom lip of the door and the door gasket with a damp sponge will prevent this build up. Hope this helps you.
May 11, 2007 | Whirlpool 24 in. DU920PW Built-In...
Maytag EPIC MFW9700S Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
