Question about Toshiba Satellite L25-S119 Notebook
Monitor I turn on the Computer but the monito doesn't turn on
  • 1,601 Answers
Can you get into bios?
Posted on Nov 18, 2007
Dell 5420 no post issue
It is unfortunate that the computer is not posting. Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    Try turning on the computer. If still the same issue then check if there are any beep codes from the computer and how the device status LEDs (Battery, power LED, wireless LED, etc). Also try connecting an external monito and check if that helps.
    Thanks and Regards.
    Kiran Kumar.
Jun 29, 2014 | Dell Latitude E5420 Notebook
When i turned on my computer, the whole picture on the monitoe is turned sdieways. on the desktop sttings it is correct.
Depending on what OS you have, try this: Ctrl+Alt+Arrow Down will rotate your screen down
If that worked thumbs up me please!
Mar 03, 2011 | Gateway 22" Widescreen Flat-Panel LCD HD...
MoNITO MESSAGE "Out of Range"
You need to lower your PC video resolution to the native resolution of this monitor.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 27, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
Hi! When I turn on the computer the monitor does nothing. Please help me what to do!
Mar 20, 2010 | MSI 645E Max2 (MS-6567) Motherboard
Compaq FP-5315 won't turn on goes to sleep every time
More likely to have bad caps with bulging top in the power supply, that is the first place to look for the monitor this old, see example of failed monitos due to bad caps:
Post back what you se sowe help you more.
Mar 04, 2010 | HP Compaq FP5315 15" LCD Monitor
When monito turned on itsay no signal all
Something is loose. Either on the video card or the monitor. Either that or the video card is broken. This would not happen for any other reason
Sep 08, 2009 | AOC Computers & Internet
My monitor shut down suddenly and won't turn on now. I restarted the pc but there was no response. The cables are connected and the button is pressed.What can I do?
do you have a video card installed?..if you do then the card is dead. try the monito on another comp to see if it works. if it does then the problem is the hardware in your computer.
Aug 30, 2009 | LG Flatron L1718S LCD Monitor
Acer X223W monito won;t wake up after sleep.
I have a dual monitor system, both are the x223w. Same problem but only on the second monitor. Backlight shuts off.On/off light stays blue. I have to turn off the monitor and turn it back on. I returned it and Acer could not find any problem so I got it back. No problem for awhile and now a few times over the past couple days. Not good...
Aug 10, 2009 | Acer 22" X223w LCD Monitor
No sound
If speakers are built into the monitor, then there should be an audio cable that connects from the monitor to the green speaker out jack on the back of the computer.
If speakers are NOT built into the monitor, then buy a set of speakers from a store.
Mar 27, 2009 | HP Pavillion s7420n PC Desktop
Toshiba Satellite L25-S119 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
