Question about HP OfficeJet 6210 All-In-One InkJet Printer
The copy turns out blank - HP OfficeJet 6210 All-In-One InkJet Printer
If using the ADF, feed it the other way around.
Posted on Jul 16, 2009
Why do we have blank copies on Xerox XC830?
is it problem when you try to copy vis adf or its aucord in platen glass also?
Sep 17, 2012 | Xerox Office Equipment & Supplies
Trying to copy a DVD--when I insert a blank DVD, it spits it out and asks me to insert another. I have tried with two different blank DVDs, and each time it spits it out without copying, and asks to...
1. your DVD blank may be rejected due to the program compatibility.
2. the DVD that is being copied was burn at a certain speed and this may have an affect on the
copy of the original.
3. the blank DVD should have the same capacity as the original or better that is if the
DVD blank has the capacity of 4.5 GB and the original is 8.5 GB then the copy has
reached it's capacity and will be ejected by the DVD burner.
I hope this helps. Have a great day.
Oct 05, 2010 | Sonic RecordNow! Deluxe 7.3
Blank copies
You need to turn off "Print Separator Page" from printer setup/properties. This usually fixes it.
Feb 11, 2010 | HP Officejet 5610 All-In-One InkJet...
Copy coming out blank
Normally a blank copy is caused by the image not being transfered from the drum to the copy paper. Which indicates a problem with the transfer step of the process, check for a bad transfer roller or a bad transfer belt. If this is not very obvious, run a copy and try to turn the machine off or open the front cover during the copy process when the copy paper is about half way under the drum and check for a toner image on the drum. If there is no toner image on the drum you may have a developer problem, broken drive gears etc. But if there is a toner image on the drum but no image on the paper then it is a transfer issue.
Sep 15, 2009 | Office Equipment & Supplies
Blank copies
see the cartridge do is good installed.
Remove the cartridge and putt it again.
If the problem do not go away please try with other cartridge.
Or if the printer is ink-jet printer and you have not used it for some time than the ink can be stuck
Jul 16, 2009 | Office Equipment & Supplies
Sharp AL 1631 ---- Getting blank copies
Hi, you can stop a copy half way to see if it image is on the on the drum if not check and make sure toner unit is turning. if not main charge. thanks dale.
Jan 22, 2009 | Sharp AL 1631 Copier
All copies are blank
What happens when you print a report? Do you get print then? If you can print reports and then you get blank copies the problem is your scanner. If you can't print or copy, then the problem is in either the drum, I would say 30 percent, or laser probably 70 percent.
But we have to find out if it will print a report. Do you use the machine as a fax ? Do they print ok?
Sep 29, 2008 | Xerox WorkCentre M15i Laser Printer
KONICA 7020 - Blank copy
I have never heard of a developer moving backwards!!!!!!!!!!!!!!!!???
the motor that runs it, the .... there is too much involved to mention. A developper moving backwards will spill so much toner in the machine anyway.
If you get a copy and then it goes blank, that tells me you have a problem with the SEPERATION UNIT, it may be shorting out causing the paper to rise against the drum giving you blank copies.
A blurr copy tells me there is a problem with the Scanner/Optics area. maybe the rails that the scanner run on are too dry or has a problem, the optics(mirrors) may be misaligned.
Not sure what you mean by (hanging) ??
Jul 31, 2008 | Office Equipment & Supplies
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
