Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
The dryer drum does not rotate. The dryer
I have a Whirlpool Gold gas dryer. The dryer drum does not rotate. The dryer displays lights up and the light instead the dryer works. The dryer door switch appears to be working. Any ideas?
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryerThe dryer drum does not rotate.  The dryer - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gifdryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 02, 2010
  • 30 Answers
There is a set of instructions available at www.AnyoneCanFixIt.com for this problem. Specifically at:
http://www.anyonecanfixit.com/household.htm
It's a quick and easy fix.
Posted on Sep 19, 2009
Whirlpool gas dryer Model GGW9200LW0. drum will not start rotation, makes temporary hum noise. after turning the drum by hand a couple time i was able to get the dryer to work for about twenty minutes. but...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 13, 2011 | Whirlpool GGW9200L Gas Dryer
Whirlpool duet electronic gas dryer noy heating up
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Jul 17, 2010 | Whirlpool GEW9250 Electric Dryer
Eleven year old Whirlpool electric dryer cannot turn the drum with a full load of towels. The motor turns on but then shuts off. It will turn a very light load.
Turn the drum by hand. It should rotate fairly easy in one direction. If so, then the motor is going out and need replacement. Fairly common problem.
Jul 13, 2009 | Estate TGDS840JQ Gas Dryer
Whirlpool Dryer Drum Won't Rotate
sounds like your drum belt has broke. remove two phillips screws at lint screen. pull top towards you then up. you will expose drum.
Jun 24, 2009 | Dryers
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Whirlpool gold electric dryer
Hi .check to see if you have 240. volts at the dryer outlet.if you do check the element .do you have a meter to check this with.if no you have to remove the element to look at it . if its broken replace the element . you can buy a cheap meter at radio shack or future shop not very expensive .you should get one ,you will use it often.
Oct 06, 2008 | Whirlpool GGQ8831L Gas Dryer
The drum doesn't rotate and a strange buzzing noise occurs
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE;
Aug 22, 2008 | Zanussi Dryers
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Kenmore gas dryer
kuki, on a gas dryer, if the thermal fuse is blown, it will rotate but will not heat. If your dryer front has a lower panel, the fuse will be in front behind the blower housing. If not, it will be in back just like this pic. Ohm it out or jump it out temp to see if that is the problem. Post back, Catriver
Aug 31, 2007 | Whirlpool LER5636P Electric Dryer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
181 people viewed this question
Dan Webster
Dan Webster
Sal De
