Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
My WD Mybook 1TB doesn't appear on my desktop?
  • Chris
    Chris May 11, 2010
    Hello, We can certainly help with this, but will require some additional info. What OS do you use, Windows XP/Vista, Mac 10.?, etc. Does the icon not show up in "My Computer" as well or does it work there? Please comment back with this info and we'll do our best to walk you through it. Chris
5 Suggested Answers
amusedgeek
  • 787 Answers
SOURCE: WD mybook world won't work on mac?
Window and OSX - fun and joy.
Since you formatted a 1TB drive and it works fine in Windows, I have to concluded the the drive was formatted NTFS.
Here is the issue in a nutshell, OSX supports reading NTFS but have very limited write cababilities.
If you want both Windows and OSX to have full access to an external drive you should format it FAT32. The only issue then is that under normal conditions a FAT32 drive has a maximum size of 32GB.
I would partition the drive to have 1 or more FAT32 partitions and then have the rest of the drive NTFS.
Is the OSX version correct or should it be 10.3. If it is actually 1.3 it would mean you have the OSX Server edition that originally came out in 1999 and it may not have very good USB support - version 1.2 would only support 1 USB device.
Posted on Oct 16, 2008
SOURCE: I just drop my WD external hard disk (Please help)
open your mybook and do some extra care repair and see what happen
Posted on Nov 20, 2008
calanan
SOURCE: Need to open WD MyBook 1TB HDD model WD10000H1CS-00
I have this same problem and found a great write-up here that has text and photos of the process. I haven't tried the process with mine but there are plenty of responses to his posting indicating success. Good luck.
- mike
Posted on Dec 10, 2008
  • 81 Answers
SOURCE: How do I format my WD MyBook Elite to FAT32
Using FAT32 these days on a current OS will half the
HDD storing capabilities especially if your unit uses'
a SATA HDD , FAT32 speed compared to NTFS is
less than half and the compression tool on NTFS
are more compact and compile better , also FAT32
is used to apply an operating system not for external
storage and if you are using your external storage HDD for holding an operating system to the HDD
will be suspectable to contracting viruses and
putting your data at risk , since the external HDD
is static and does not run through the OS registry
Posted on Jan 29, 2010
Cannot get 1TB WD MyBook to work on NetGear N600 Router
this link is quite illuminative
click here please
seems that drive configuration needs to be done when connected to pc first then after it's recognized, added to network router
May 21, 2012 | Western Digital Computers & Internet
I have a WD MyBook Essential 1TB external hard drive installed with my Mac OSX 10.5.8. The drive is only being used for Time Machine and my iTunes backup. The drive will randomly unmount itself and I get...
I would suspect that either the USB cable or port is the problem. Change the USB port (On the Mac or on the WD MyBook (I don't know if it has more than one USB port) that the cable is connected to and see if that improves the situation, if it still happens change the USB cable. Hope this helps.
Mar 22, 2011 | Western Digital My Book Essential 1TB...
My wd 1tb mybook no longer powers up-I have archived versions of these files but i would prefer to get the data off this drive
Is it still under warranty?
Possibilities:
* try connecting to a different USB port on your computer
* try connecting to a USB port on a different computer
* try a different USB cable between the computer and the MyBook
* disassemble the casing, and remove the disk-drive, and connect it as a "slave" drive in some desktop computer, to see if the files on the disk-drive are intact
If all else fails, search online for "professional data recovery service" -- a company that will repair the MyBook just long enough to copy all your files onto a new disk-drive. Of course, this is _expensive_.
Note that Western Digital has a Customer Loyalty Program -- knowing the serial-number on your disk-drive, you can buy a new MyBook from their web-site, at a good discount.
Apr 23, 2010 | Western Digital My Book Essential 1TB...
WD mybook 1TB is gone from the network
Have you tried different cables or a different port on your router. Is there any way to get into the Hard Drive by connecting it directly to a PC and checking the network settings or anything..? If not, then you may have to connect it directly to a PC and share it to your other PC's.
Sep 15, 2009 | Western Digital My Book World Edition 1TB...
WD My Book 1TB Ethernet seems to hang my USB ports on my notebook
Update your firmware, i had the same problem, i updated the firmware and everything works fine now.
Jul 04, 2009 | Western Digital Computers & Internet
I am having a problem copying large mkv files from a WD 2TB mybook to another WD 2TB mybook. they are both formatted to NTSC. I had no problem loading the first drive but the second one is giving me fits!
In order to fix this problem, be sure that the drive is formatted to NTSC. Mine was, however, when I started loading mp3 files to the drive first, it somehow got reformatted to FAT32. I don't know how, but it did. Copy your mkv files FIRST!
Apr 14, 2009 | Western Digital My Book Essential 1TB...
WD 1TB working properly for some time
Make sure the power supply (power brick) for the mybook is working. (unplug both ends or the power cable and plug back end)
do the same for the USB cable. Still no luck? Plug the USB connector into a different port on the PC and see if that changes your luck.
Feb 27, 2009 | Western Digital My Book Essential 1TB...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
441 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
