Question about Canon ZR70MC Mini DV Digital Camcorder
Digital video camcorder
I purchased a canon mini dv 4-5 years ago and not used in 2-3 years. I recently tried it and could not power it up. I replaced the thin 3v battery, still no luck. Any ideas?
  • 38 Answers
Re: digital video camcorder
Try the most obvious solutions first; making sure the AC adapter for the camera is plugged into the camcorder-- and the plug orientation is correct if applicable, and it is in turn plugged into the wall.
Is the wall outlet working? Try another location in your home to be sure. Is the AC adapter working? If you have a battery, attach it to the camera and see if it charges. Next, look for obvious outward physical damage to the camcorder that could cause it to stop working.
The thin battery you speak of if generally just for backing up the time and date, and is not needed for operation.
The power switch on Canon models is usually a slider that goes from Manual to Auto to VCR mode. If it is dirty or wearing out, move it a small amount to one side or the other, while watching the LED power indicator. If you see it flash, or light dimly, the switch is bad.
Read the manual-- the unit may have a reset function you can access, or require a tape in it to power up. Hope these help.
Posted on Nov 18, 2007
0 characters
3 Points
Can I hook up to the DW 100 Canon burner with my ZR200 to burn mini tapes on DVD?
No. The Canon USA web site says the Canon DW-100 has a USB terminal and works with "USB 2.0 Hi-Speed (with compatible Canon camcorders only)." In other words, the Canon DW-100 burner works only with Canon's USB 2.0 camcorders. I have a Canon ZR200. The ZR200 has Firewire 400 digital video output, not USB 2.0 output. The USB port on the ZR200 is ONLY for still images. Video will not and cannot be output through the USB port on the ZR200. (Page 121 in the ZR200 manual mentions using the USB port on your camcorder for transferring still JPEG images to your computer.) You need a DVD burner with "DV Input" (also called Firewire 400 or IEEE 1394) to hook up your camcorder to burn Mini-DV tapes onto DVD. The Sony VRDMC10 Stand Alone DVD Recorder/Player has DV Input. The ZR200 camcorder did not come with a Firewire cable, but you can buy one at any electronics store or at a cheaper price online. Make sure that you get the right kind of Firewire cable, 4-pin to 4-pin or 4-pin to 6-pin, whatever the DVD burner you choose requires. (Your ZR200 has a 4-pin DV port on the camera's end.) USB 2.0 Hi-Speed (with compatible Canon camcorders only)
Mar 15, 2011 | Canon ZR200 Mini DV Digital Camcorder
How to convert dv tape from Canon ZR20 to MY COMPUTER hard drive?
To transfer video off your minidv cassettes from your camcorder you would need to have a firewire connection to your PC. Either a 4 to 4 pin connection (laptop) or a 4 to 6 pin (desk top computer). USB is used only for picture still transfer. Here are the steps;
1. Plug your mini Dv camcorder into an outlet
2. Plug in you firewire connection into your computer, then plug the other end into your camcorder.
3. Turn on your camcorder and switch your camcorder to Play/VCR
4. Select the software that you want use to do the transfer. Windows Movie Maker is the most assessable software since you have XP on your computer
5. Name your file
6. Select capture from video device (automatically will allow you to save the entire tape and manually would allow you to capture parts of the tape).
Those are the basic steps in some detail. You can save your file from there or you can go on to edit.
Jan 02, 2009 | Canon ZR20 Mini DV Digital Camcorder
Canon ZR200 camcorder mini dv
Have any of you tried using a mini DV cleaner on your cameras? I'll try this soon and report back.
Nov 27, 2008 | Canon ZR200 Mini DV Digital Camcorder
Sony Camcorder Mini DV tape doesn't go in
Have you cleaned the tape deck at all? That might work.
Jul 04, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
Dumping video
purchase a firewire cable to go from dv port of cam to computer-4-4pin for laptops 4-6 pin for mac and towers if comp has no firewire port-use pinnacle dazzle to convert a/v output to usb 2.o
May 17, 2008 | Canon ZR100 Mini DV Digital Camcorder
Cannot transfer from camcorder to computer.
make sure you are using 4 pin to 4pin firewire which looks like this:
After connecting,
Switch on the Cam.
Open Windows Movie Maker and import video from device.
Mar 25, 2008 | Canon ZR700 Mini DV Digital Camcorder
Canon ZR40 would not turn on
The battery is probably so dead it is using all the power from the wall supply.  Remove the battery, and run only from the wall supply.
Dec 16, 2007 | Canon ZR400 Mini DV Digital Camcorder
Canon ZR70MC Mini DV Digital Camcorder just stops
Hello, Sorry to hear that your Canon ZR70MC is not functioning. It would be our pleasure to assist you in being able to capture your once in a lifetime memories again. What is the estimated purchase date of the camcorder? If it is still under warranty the repair will most likely not cost you anything. Camcorder Repair
Sep 08, 2007 | Canon ZR70MC Mini DV Digital Camcorder
Sound is ok, but do not record images.
I have had the same problem since I purchased mine 4 years ago and it has been repaired 3x and is in the shop for a 4th. I had the extended warranty and Futureshop refuses to acknowledge that it is a Lemon and should be replaced as they don't consider resoldering wires as a "repair". My unit has been in the service center a total of 12 weeks over the 4 years. The service center recommends Sony Camcorders and the Claim center said they get few Sony camcorders so I would say the Canon problem is an issue that is common. Sorry to say. Mike
Jan 08, 2007 | Canon Optura 10 Mini DV Digital Camcorder
Only DV connections (IEEE1394 connections) are possible when connecting your camcorder to a computer. DV connections (IEEE1394 connections) Your camcorder can be connected to a computer equipped with an IEEE1394 (DV) terminal or OHCI-compliant IEEE1394 capture board. You can transfer taped recordings (digital video signals) to the computer by connecting the camcorder to the computer. Use the editing software supplied with your computer/capture board to transfer video recordings from tape to the computer. If you are using a computer running Windows XP, you can also record the video simultaneously on your computer's hard disk and on the tape using DV-PC Recorder Software. You can download the DV-PC Recorder Software from Canon's DV-PC Recorder Web site. Making the connection Connect the camcorder to the computer as shown in the figure below. The computer's IEEE1394 (DV) terminal is either a 4-pin or a 6-pin type, depending on the computer used. Use either the CV-150F (4-pin - 4-pin) or the CV-250F (4-pin - 6-pin) DV cable (sold separately), whichever fits your computer's terminal. Precautions (1) There are cases where the connection may not work correctly, depending on your system specifications/settings. (2) If the computer freezes while you have the camcorder connected to it , disconnect and reconnect the DV cable. If the problem persists, take the following actions. (2-1) Disconnect the DV cable from the camcorder and the computer, and then turn off the camcorder and the computer. (2-2) Turn the camcorder and the computer back on and then reconnect them with the DV cable. (3) Your camera cannot be used with DV NETWORK SOFTWARE (DV Messenger).
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Canon ZR70MC Mini DV Digital Camcorder Logo
96 people viewed this question
Top Canon Video Cameras Experts
Sheryl Bahr
Sheryl Bahr
Chris Phillips
Level 1 Expert
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
