Question about Technics SL-1200MK2 Turntable
Technics 1200 mk2
Turntable hesitates when turned on. sometimes the 33rpm and the 45rpm will light up at the same time and the turntable will go very fast . some time the light on the on and off switch will go on and off.
  • brendoldj Mar 14, 2009
    When turn the switch on the turntable begins to spin faster, the lights
    33 and 45 are turned on and the light both of the column on / off is
    off. The buttons do not respond to commands, the only way to stop it is
    to put off.
    Novelist:
    Champion:
  • 382 Answers
Sounds like a short on the pcb, one of the IC's could have gone bad, or the 33/45 have shorted out. Unless you have the proper tools i can only direct you to who you could send it to or order the part(s) from. If youre good at soldering and can work in square inch spaces, go for..
http://www.djproaudio.com/cgi-bin/Help/pdesk.cgi?do=get_download&id=2&filename=MK2_cabinet.jpg
http://djproaudio.com/Store/advanced_search_result.php?keywords=Technics
http://djproaudio.com/Home/
Keep me posted.
Posted on Nov 19, 2007
Record play 45rpm
just buy a new unit if you ain't got friends to help you.... and45.
Or see how far your goes?
Jan 28, 2014 | Stanton T62 Turntable
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
SL-1200 Turntable: My brand new Technics 1200 MK2 sounds wobbly when ...
Try plugging it into a different power point. The problem is with the power supply fluctuating. You can eliminate that with a UPS, here is a link to wiki http://en.wikipedia.org/wiki/Uninterruptible_power_supply
styluscity@gmail.com
May 10, 2010 | Technics SL-1200 Turntable
GOING FROM 45 TO 33
I don't know if this model is direct driven or by belt. If it's belt driven then the belt could be fitted incorrectly, or faulty. Another possibilty is that there's a fault in the motor control circuit.
Jul 28, 2009 | Gemini PDT-6000 Turntable
Turntable 45rpm speed has stopped working
Check that the lever is actually making the contact with the 45 rpm switch position and completing the circuit as it would seem everything else works. The only other thing it could be is a break on the pcb, but that is unlikely.
Oct 17, 2008 | Philips Audio Players & Recorders
Technics 1200 MK2 displaying irregular speed to include dragging and slowing
It sounds like the pitch slider needs to be replaced...
Mikey's Hook-up
88-90 North 6th
Brooklyn, NY 11211
Cover insured UPS charges both ways and you will get sorted.
Oct 23, 2007 | Technics SL-1200MK2 Turntable
Technic 1200 mk2 turntable wont spin
need to know if it powers up. Does it try to spin, do you hear it trying to spin? More than likely the on/off switch went bad. No, I am not referring to the ON/OFF knob. THere is a switch this engages when turned. The part is S601. You might also want to replace the Start/Stop switch as well. If neither work, then the issue is on the main PC board, and probably IC101, or IC201 with the problem. At this stage, you will have to have a service tech look at your unit.
Oct 19, 2007 | Technics SL-1200MK2 Turntable
TECHNICS SL1200MK2 RPM Buttons getting stuck..
Ed try spraying some contact spray directly in to the Buttons,push one then the other you will feel them free up Please rate my performance ttech
Jul 21, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
664 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
