Swamp cooler is not blowing cool air - Heating & Cooling
  • 146 Answers
Is the units Disturbing the water over the pads!
if not check the water pump!
are the pads old and worn out, buy new ones.
and if the Humidity is to high they do not work well
Posted on Jul 17, 2009
4 Suggested Answers
fireman23
  • 6 Answers
SOURCE: Hot Air from the cooler
check the a/c unit. make sure you dont have any leaks around your system. sometimes when you have a small leak it will take time to lose out of system. but you may need to charge your unit up again. Also your compressor may be out of service. check and make sure compressor is running
Posted on Apr 01, 2009
  • 340 Answers
SOURCE: swamp cooler is not blowing cold air. Water is
is the pump youll have to take off a panel make sure the pump has water. what is the relative humidity if it is high swampers don't work very well .Tom
Posted on Jun 26, 2009
Devious1969
  • 76 Answers
SOURCE: how to turn it on? wisper cool
Try this : http://www.impco.com.mx/manuales/artic/Manual%20MMB8.pdf
Posted on Sep 13, 2010
Can you usen the sam air vent for heating and swamp cooler
Yes you can. I have that set-up in my house. The only problem is when moisture laden swamp cooled air goes past the heat exchanger. This could cause the exchanger to rust out, allowing carbon monoxide to come into the house when the heater is used. This can be avoidid by having a one way damper made by an HVAC shop, and installing it at the heater.
Apr 16, 2012 | Mastercool 67680 Evaporative Cooler Air...
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
How do you calculate the cfm in a swamp cooler
You will need to figure the cubic feet of space you want to cool, and then divide that number by two. The quotient will give you the CFM rating for the proper-sized swamp cooler.
Jun 14, 2011 | Heating & Cooling
We have an older swamp cooler and need to have some windows in our home open to get best cooling. Does a mastercool need to have some windows open in our home to give max cooling?
The solution is to install "up ducts" These devices are easy to install and are fairly cheap. With a swamp cooler the best way to use them is to allow them to draft outside with the "up duct" you get the drafting to the outside but also get to remove attic heat too.
Apr 24, 2011 | Mastercool 67680 Evaporative Cooler Air...
Swamp cooler works i can hear the pumpon water is turned on but not getting cool air
just because the pump is on dose not mean its moving water. impellers can break and pump can get air lock
Aug 01, 2010 | Mastercool 67680 Evaporative Cooler Air...
Swamp cooler is not blowing cold air. Water is
Jun 25, 2009 | Heating & Cooling
Frequent short cycles of the Mastercool swamp cooler
Short cycling can also occur in a thermally protected motor if it is overheating. If the other solution did not work, make sure the belt on the motor is not too tight or too loose. A handy person can check the amperage with an amp probe to make sure it is in limits. The adjust the pulley to put it into specs.
May 27, 2009 | Mastercool 67680 Evaporative Cooler Air...
Do not know how to work/maintain swamp cooler
Make sure you have water to the unit, the water pump is on and the fan is working. No water=no cooling.
Apr 21, 2009 | Mastercool 67471 Evaporative Cooler Air...
Replacing pads
How do I replace a rigid pad on my Mastercool swamp cooler?
May 22, 2008 | Mastercool 67680 Evaporative Cooler Air...
Shouldn't it be cooler?
Just found at least one problem with mine. I pulled off the back screen and then pulled off the back cover by undoing the two screws at the top. There is a pad in there that rotates through the water reservoir. If this pad doesn't get wet, you won't get any cooling. My pad was bone dry. Turns out the wire for the motor that rotates the pad was disconnected from the front control panel. I reconnected the wire and now the pad rotates through the water reservoir. We'll see how this works.
May 21, 2008 | NewAir AF-330 Air Cooler Fan
Heating & Cooling Logo
273 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
