Question about Refrigerators
Water not dispensing from water dispenser on refrig. worked fine last night and this morning nothing.
  • 245 Answers
Check to make sure there is water to the fridge. after that check the water solenoid valves on the back of the fridge where the water line hooks up .
Posted on Jul 16, 2009
My ice maker is working, but it will not dispense. Light comes on when the dispenser is pressed, but motor does not run. Can't see anything physically wrong. Water dispenser works fine.
Its got to be the switch. mine stopped working last night, after reviewing the wiring diagrams it is a simple circuit. if the motor is not turning in the cubed or crushed mode and it is not locked out it has to be the switch. I will take mine apart a little later this morning. I expect to find that the micro switch has failed. should be an inexpensive fix
Apr 05, 2010 | KitchenAid Superba Architect KSCS25INSS...
Water dispenser doesn't work, side by side, model # GSS22JEPA BB
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Mar 04, 2010 | GE Refrigerators
Water dispenser not working
There are two electric valves for your ice maker One for water to make ice and the other is for your water dispenser. They can get clugged and will not dispense water. The two valves are sold together for $50 and they are right in the back of your Refrigertor where the water pipe ends. Hard water can clugg those tiny valves
good luck
Jul 31, 2009 | Refrigerators
Water dispenser worked perfectly for 9 months. Today, no water comes out at all.
hi michael! you may have to get out your owner manual and read about how to change the water filter. get back if u need assistance
May 09, 2009 | Refrigerators
GSS25LGMF WW Will not dispense ICE or Water, lights are on
Hi, I have had a similar situation. In my case the filter needed to be replaced. Otherwise the water solenoid is bad or clogged. And check the water supply valve. Best of luck. , Tim
Feb 13, 2009 | GE GSS25LGM Side by Side Refrigerator
GE GSS25SGRE side by side water dispenser...
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Buzzing sound from interior light bulbs
sounds like you have an issue withthe electronic control board locates behind refrig next to the compresssor, in a white housing
Dec 30, 2008 | Amana ABB1927DE Bottom Freezer...
No agua !
you would have to start with the water supply.
check if you have water coming to the fridge.
close the tap going to the fridge, open the line to the solenoids and open the tap. if there is water then supply is ok.
next check if there is power going to the water solenoid . ( this is different from ice maker solenoid) be sure to know which one.
press the dispenser, there should be power to the solenoid and solenoid should click open. if there is none, electrical problem is present.
last thing to check is the micro switch in the dispenser.
it should have contact when you press the dispenser.
tnx 4 using fixya,
drcool
Oct 29, 2008 | Samsung RS2534 Side by Side Refrigerator
Dispenser not functioning & control panel inside turned off
you have a bad control board in the rear of the unit ...>>>>> To verify this check for 13.5 vdc on red and black going into the display board?? since your dispenser is not working the control board is most likely not working. puill the refrig from the wall and remove the cover plate it is square about 5"X6" you will see the control board thew part # for this is WR55x10552 if you need to replace it let me know
Apr 01, 2008 | GE PSS26SGR Stainless Steel Side by Side...
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
