Question about Spectra Logic 5-CTV 5 in. Television
My Spectra Model 5-CTV has no color. The screen is showing nothing. I have tried moving the bright of color nobs but I still can't get anything.
Sony TV channel stuck on 56 I need it on channel 3
Doesn't Channel + & - button work?
Let me know to guide you more.
Oct 27, 2008 | Televison & Video
My laptop display very dim
If your HP laptop has a dull screen, or if the screen is too bright to make out anything that's displayed, you may need to adjust the brightness to get your screen back the way you like it. You don't want to strain your eyes to see your screen, and the fix is really simple. It's about as easy as adjusting the brightness on a TV. You'll have your brightness set the way you want it in a few seconds.
1. Right-click on an empty space on the desktop and a drop-down menu will appear.
2. Click on "Properties." If the HP laptop uses Windows Vista, you'll click on "Personalize."
3. On the "Personalize appearance and sounds" screen, click on "Window Color and Appearance."
4. Click on the arrow beside "Show color mixer."
5. Use your mouse pointer to move the tab on the "Brightness" scale to the left or the right to adjust the brightness and click on "OK" when you're content with the color.
I hope you find it very helpful. Thank you for using fixya.
Best regards.
Aug 15, 2011 | HP G62144DX Laptop
Tv spectra model ce-6443 can't unlock
Press the DISP button and hold for 5 sec.
This should unlock your Spectra TV.
Jul 19, 2009 | Spectra Logic 5-CTV 5 in. Television
Dark picture
you know it sounds like the same problem i had....
look this is something you can try.... "turn the tv off and unplugg it!!!"...you'll need to take out the lower front part of the tv......(where the speakers are to be exact) on each lower end you will find 2 screws..Be careful it will open to the side and there are many wires, i suggest you mark them to know where to put them back...then right in the middle there will be a black cover with about 5 screws..take them out....and look at the very bottom you'll see a thing with 6 pegs....the top ones are for the screen "DO NOT TOUCH THEM"...the ones on the bottom are for the colors...re adjust them...the left one it's for blue, the middle one it's for green and the last one it's for red...
I had the same problem after i moved....and after i re adjust that the tv looks super...
i hope that helps..:P
Sep 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Philips 9P6040C 60 in. Rear projection
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Here are some of the most common symptoms.
  • Screen looks 3D
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site http://www.TvRepairKits.com . They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Jul 23, 2008 | Philips 9P6040C 60" Rear Projection...
Digital signal
Most of the small (5") TV's do not receive digital, especially if they are more that a few years old.
Jul 15, 2008 | Spectra Logic 5-CTV 5 in. Television
Everything has a reddish/orange tint
i have the same problem pull off the back of the tv and mess with the color nobs it helps a little
Oct 10, 2007 | Philips 9P6040C 60" Rear Projection...
Sony Rear Projection TV Model # KP 53N74
I have had a similar issue with a Sony 52" circa 2001 tv. It was bad and then got better. The only problem now is that when I plug anything into the component 1-5 (but not 4) the screen is fuzzy. The DVD is plugged into 4 and it works fine. I tried plugging something else into that and it showed up in black and white. Very frustrating. Fancy TV if you only watch cable or a DVD. All other modes show up fuzzy. Sony recommended a tv repair place in St. Paul but they want around $400 just to look at it.
Sep 26, 2007 | Televison & Video
Spectra Logic 5-CTV 5 in. Television Logo
53 people viewed this question
Top Spectra Logic Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Spectra Logic Televison and Video Expert? Answer questions, earn points and help others
