Question about Brother CS-8060 Computerized Sewing Machine
Just got E1 error message on my brother CS 8060
I am a fairly new sewer & was just happily using my brother CS 8060 & just changed bobbin & went back to sewing my project & got error message E1... i made sure bobbin in correct and all is well but e1 message wont stop..anyone know how to fix the problem, my manuel tells me what i may have done to get error message, but not how to fix it......very frustrated...thanks for any help
  • trishdadish7 Jul 17, 2009
    i fixed it myself... one time i got an E6 error message a couple months ago or so.....coudnt get rid of it...i dont know why I decided to open up the thread spool compartment and closed it again.....but it made the E6 error message disappear & it began sewing again...so when i got the E1 error message yesterday,I decided to do the same thing...message went away and it sews again! wierd huh!...i have no idea the connection of it..as i hadnt opened or changed the thread prior to the error message...but now my bobbin wont wind.. it did the other day!!!!! any help out there?
SOURCE: Display shows E1
I think I have the solution, it happened to me.
The instructions for bobbin winding tell you to click the start button for the bobbin to wind. When you do that you get that E1 with a beeping. What they don't explain is that in order to press that "UP" arrow button to get the bobbin to wind..........you need to UNPLUG the foot control. So, in other words it to be used for sewing w/o a foot pedal. Now instead of doing as per instructions, assuming you've plugged everything in (foot pedal), after winding is finished just press the foot pedal and your off and running or sewing as the case may be. BTW, look it up in the TROUBLESHOOTING SECTION OF YOUR MANUAL. Hope this helps.
Posted on Nov 10, 2008
SewTechWayne
  • 186 Answers
SOURCE: After replacing the bobbin on
Make sure the bobbin winder is not engaged. If this doesn't help, let me know the model and make.
Posted on Jan 30, 2009
SOURCE: i can't sew on my machine
I had the same problem.There is a gold or silver washer on the back of the sewing machine that holds the part inside that you are connecting to. If the washer is gone or loose you will not get a connection when you insert the foot peddle. This peice inside is small and square with three delicate wires attached, You should be able to see it
Posted on Feb 05, 2009
  • 8 Answers
SOURCE: brother CS 8060 bobbin wont wind...but motor runs
no idea... did you lock thread onto bobbin so it holds to wind?
Posted on Jul 18, 2009
  • 30 Answers
SOURCE: mass bunching of thread in the bobbin compartment
it had nothing to do with the shuttle, it is the upper thread is not in the tensioner. lift the presser foot up and thread the machine even if you have to hold the thread on the top and pull on the bottom to make it go in the tensioner it will help, if a machine loops on the bottom it is the upper tension if it loops on the top it is the lower tension
Posted on Aug 22, 2009
Why does error F7 flash on my brother cs8060 sewing machine and how can I fix it?
Any "F" error message, F1 through F8, can indicate machine is malfunctioning and needs servicing. You can check with Brother.
Sep 02, 2014 | Brother CS-8060 Computerized Sewing...
Bobbin shuttle doesn't move
Look in your book.
- There is a bobbin (clear plastic) it rotates.
- The bobbin fits into the bobbin case (black), it does not rotate.
- The bobbin case is nested into the shuttle which does rotate.
There is no bobbin shuttle.
Aug 19, 2014 | Brother CS-8060 Computerized Sewing...
Ihave anerror E6 and I can no find the problem
Hi! The E6 error means the thread is tangled. I suggest you completely unthread the machine, including the bobbin. clean out any lint or bits of thread in the bobbin area, and carefully rethread.
Hope this helps!
Robbie
Feb 15, 2010 | Brother CS-8060 Computerized Sewing...
Bobbin winder does not spin
Hi. I have a CS-8060 and while I love the machine--the bobbin winder isn't my favorite. Anyway, I have found that the cover to the bobbin winder must be opened completely, also the thread spool must be as far back as possible. Another place I'd check is with a small flashlight just under the small bobbin spool. It can be hard to see under there, so a small flashlight helps. I have gotten thread wound around the pin that goes up to hold the bobbin and if sufficient thread has gotten up in there it could keep the spool from spinning. It's hard to clean out, but careful use of a seam ripper and tweezers does the job.
Good luck and let me know if this works.
Robbie
Jan 11, 2010 | Brother CS-8060 Computerized Sewing...
Mass bunching of thread in the bobbin compartment
Aug 22, 2009 | Brother CS-8060 Computerized Sewing...
Brother CS 8060 bobbin wont wind...but motor runs
Jul 17, 2009 | Brother CS-8060 Computerized Sewing...
Sewing Machine CS-8060
I do have the very same problem! I took my bobbin case out and took a good look at it, turns out right below the plastic hook part, the plastic was cracked off (probably due to thread jamming). Turns out I need a new internal bobbin case, which range in price from $35-$50 from what I researched. I had no luck with local sewing centers on finding the part.
That may (or not) be your issue as well. Good luck, and I hope this your issue is simple fix. A little tune up after might be needed, HAPPY SEWING!! ~Kelly J~
Sep 26, 2008 | Brother CS-8060 Computerized Sewing...
Brother CS-8060 Computerized Sewing Machine Logo
237 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
