Question about Maytag MER6772 Gemini Electric Kitchen Range
The buttons on my display are not working. Some of the buttons will work, but then others will not. If we unplug it, we can sometimes get it to work, but it is getting frustrating.
  • Maytag Master
  • 3,361 Answers
Unplug the range. Open the control console. Remove each connector from the clock mechanism and then replace them firmly and try again. If it still does not work correctly you will have to replace the electronic control.
Posted on Jul 16, 2009
E500i-B1 won't come on.
Suspect a failing power supply
Jan 13, 2017 | Televison & Video
The display is suddenly filled with information (sometimes unreadable). Everything has now stopped working.
From the sounds of it the microprocessor is scrambled, this can be caused by a power surge or thunderstorm, unplug unit, press and hold power button for 60 seconds in an attempt to clear the processor, if this fails this will be a job for a Bose factory trained technician.
Sep 16, 2012 | Bose Wave Radio
My LGHD1209 the buttons aren't working properly, sometimes the power button responds when pushed but no others....
Try unplugging it and waiting 10 mins for any capacitors to discharge. Switch back on and retry buttons. If no go, control panel fault
Apr 28, 2012 | LG LWHD1209R Air Conditioner
No picture or sound
This happened to me with my 5080 also. No amount of messing with the remote inputs/menus/controls would work. The menus and on screen info displayed, but would not display any input. Solution was to unplug the power cord (not turn off, UNPLUG), let it sit for a while, then plug it back in. It came right back. Apparently the onboard computer gets a little confused sometimes and removing its power source clears it out.
Apr 29, 2010 | Pioneer PDP-5080HD 50 in. Plasma HDTV
How do i reset a brother mfc 240c
To reset the MFC-240C, hold down the power button for 3 or 4 seconds. The lights on the display should go out and the printer should slowly turn itself off. Once it is off, hit the power button again to restart it.
If the power button does not work (as sometimes happens with paper jams or other error conditions) you can unplug the machine's power cord in order to reset it.
Oct 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
Whirlpool duet control locked
Whirlpool GHW946PLO locked controls light is on and will not respond. Have tried to unplug to reset default codes.
Jul 09, 2008 | Dryers
Won't switch to tuner
Sounds like the source button is not working properly. I have seen this type of problem caused by a crack in the display board. It can also be a bad contact on the source button.
Could be several other things as well, but most of the time it is something like a cracked board.
You can also try resetting the unit, look to see if there is a very small pin hole sized button on the display someplace, if so, use a paperclip or a toothpick, ect. to depress that switch. you might get lucky and the micro just needs to be reset. Sometimes you can reset a unit by disconecting the power wires for a few seconds, or just unplug the harness in the back for a short time.
Hope this helps
Jun 16, 2008 | Pioneer DEH-1300 CD Player
Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Nov 14, 2007 | Panasonic RX-ED707 Boombox
No display on Sony CDX-M800
JUST PRESS THE RESET BUTTON
IF THIS DOSNT WORK CHECK THAT THE PLUG WIRES ARE SECURE I HAD THIS PROBLEM LAST YEAR AND IT TURNED OUT THAT ID UNPLUGGED THE STEREO BUT AS I RECONNECTED IT THE PIN HAD PUSHED THE CONNECTOR AWAY SO SOMETIMES IT WORKED OTHER TIMES IT DIDNT WHEN I HIT A BUMP IT WOULD MAKE THE CONNECTION BREAK
Nov 08, 2007 | Sony CDX-M800 CD Player
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Maytag MER6772 Gemini Electric Kitchen Range Logo
126 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
