Question about Juki TL2000Qi Sewing & Quilting Machine TL-2000Qi, 6x9" Arm Space, Extension Table, Drop Feed, Knee Lever 1/2" Foot Lift, Walking Foot, 6 Feet TL98Q
Foot petal not working..but machine has power has power..brand new machine..also needle up/ down not working
    Top Expert:
  • Juki Master
  • 11,573 Answers
Janice, Return for exchange or refund, faulty machine.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Posted on Apr 09, 2016
I am sewing with my Euro pro machine using the walking foot. The needle is sticking win the down position
I suspect it has more to do with the needle, thread, and fabric than the walking foot. Try installing a brand new sharp needle, perhaps a top stitch needle will pierce the fabric better.
Mar 21, 2018 | Sewing Machines
Needle on my Singer Simple acts like it is hitting something when fabric is in machine with foot down. Take fabric out and needle passes through.dont know what to do
Install a brand new needle and see if that takes care of it. A bent/damaged needle could strike parts of the machine.
Feb 05, 2018 | Singer Sewing Machines
My needle keeps hitting the presser foot. I cannot see any adjustments to make. I have taken everything off and re tightened.
make sure that you have the right for installed for the sewing pattern involved
the straight sew foot will have a hole that the needle works through but if you have it on button hole , zigzag or any other pattern that moves the needle sideways then the fot will be slotted
check for bent needle or thread tension excessive and pulling the needle sideways on the down stroke
Sep 19, 2016 | Sewing Machines
What might cause my sewing machine to not respond when the foot pedal is depressed?
make sure the plug for the foot pedal is connected securely to the machine.
could be the plug in the machine has a problem even tho the foot petal is plugged in
could be the foot petal has gone out and needs to be checked.
Jul 27, 2014 | Husqvarna Viking 1
Foot petal is not working and it is plugged in.
Is there power, does the sewing bed light come on? If so there is probably a fault with the pedal. If you are practical you can open the pedal and fit a volt meter across the terminals to see if the voltage increase when the pedal is pressed.
Feb 11, 2014 | Singer 7422
My daughter's brand new, right out of the box Janome 2212 machine is not working. The foot pedal is not engaging the motor so the needle doesn't move up and down. The wheel is pushed in as it
Sorry, but gotta ask is it plugged in and turned on? Check before you answer. (I ask this because it happened to me, set up, ready to go, and no power. After an hour and the machine was in pieces, My son asked if i plugged it in and I snapped "YES, DUH" not seeing him twirling he plug in his hand...he informed me that you must be 10% smarter than anything you operate or eat....at which point he was happy to inform me, the machine was 11% smarter. If it is plugged in and turned on, is the plug to the foot pedal plugged all the way in? Is the machine on? If you get zero reaction, no movement or sound of any kind, the foot pedal my be faulty, it can happen. Take it back to the dealer and they should replace the entire machine or the foot pedal. Good luck and happy sewing.
Jan 10, 2013 | Janome 2212 Sewing Machine
I have a brand new Sony BM-850T2 destop transcriber. Right out of the box, when you use the foot petal to reverse, pick up your foot the tape continues to reverse. The lever that you use to set the number...
This Sony model has a scan feature that reads index info on the tape. If the tape is recorded on a non Sony unit, you may have this issue. To turn this off, Hold both the Stop and Reset buttons together for about 5 seconds. The display will now only show the counter, no indexs, and your problem should be resolved. If you lose power, you will need to do this again.
Sep 16, 2011 | Sony Audio Players & Recorders
I have a babylock 1556 and when I press the foot petal the belt turns, but it won't move the needle up and down. I took off the back so I could watch and see what was going on. I can see the belt...
On the side of the 'knob', look for another wheel that tightens against that, so it engages, that's what it sounds like. When that second wheel is loose, it won't run, it just spins. From the photo I can find of the unit, it looks like that second wheel is below it, but I can't be certain. Let me know how you make out. Please rate and comment, thank you,
Joe
Sep 04, 2011 | Baby Lock BL1556
What foot do I use for strraight stitching I have an Elna 3005 model sewing machine Thanks
Ideally you want a foot that looks like this with a very small hole where the needle goes down, to maximise the pressure onto the fabric. Just don't move the stitch setting to anything that swings the needle or you'll smash the needle onto the foot and risk damaging the machine.
But unless you are having issues with the fabric being pulled down into the feed dogs, the regular clear sewing foot should be fine for most work and is certainly easier to see what you are sewing.
tally_girl_69.jpg A lot of quilters go for a 1/4" foot too which gives you consistent 1/4" seam widths when piecing quilts. There is a excellent website on sewing machine feet and their different purposes, link is
http://sewmamasew.com/blog2/2009/06/feet-feet-feet/ and she has great images of 1/4" foot in use along with others such as Open Toed or Roller foot.
If you are shopping for different machine feet, you may like to look at www.sewingpartsonline.com, great website with lots of different brands. Your machine would be classified as a "low Shank" machine I think; often you can buy a generic brand foot which will work on different brand machines once you are sure of the shank type.
Most sewers find that there will be one foot they prefer to use for much of their work depending on their projects. My all time fav is the Elna Teflon foot, a black teflon coated foot which works great on many different fabrics; I've worn the black off the bottom of two of them!!
Jul 23, 2011 | Elna 2005 Mechanical Sewing Machine
Juki TL2000Qi Sewing & Quilting Machine TL-2000Qi, 6x9" Arm Space, Extension Table, Drop Feed, Knee Lever 1/2" Foot Lift, Walking Foot, 6 Feet TL98Q Logo
677 people viewed this question
Top Juki Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Juki Furniture Expert? Answer questions, earn points and help others
