SOURCE: new battery, radio won't work
Hi.
Go to your local dealer and ask them to unlock the radio, changing the battery or removing any post from the battery will render theft deterrent radios to the locked state.
And your dealer has the key needed to unlock the radio.
HTH.
Zues
SOURCE: 2008 Pontiac Gran Prix,Radio MP3 line-in/aux-in
The upscale model is the only that i know of that has one. What model do you have?
SOURCE: 2008 Saturn Aura - blower motor works
I would first check the plug to the blower and possibly the plug to the resistor, sometimes these get hot and will loose connection.
SOURCE: How do I remove my stock radio form my 2008 Saturn
I will not laugh, this happens alot. There is small face plate around the radio and a/c panel with a small pick pull the panel out which will expose the screws that secure the radio. remember if you disconnect the power from the radio you will have to go to a GM dealer to have the radio reset so it will work
SOURCE: how to change a headlight bulb in a saturn aura?
Access to change the headlamp bulbs is through the wheel well. The recommended method is to remove the front tire and then the plastic inner fender liner. Once removed, you'll have easy (more or less) access to the rear of the headlamp housing.
