Question about Toshiba DVR620 DVD/VHS Recorder Black
I dropped the unit. opened everything up try to figure what might be out of place
I dropped the mic of my magic sing and now it won't even turn on even with new batteries. My brother tried to open it and he said everything looks fine inside. I don't know what else to do. Help!
Dropped microphones could disconnect the display/control board from the motherboard. If so, you cannot turn it on using the power button and neither could you see anything on the display. To correct this, you have to open up the unit so as to push the mother board unto the display/control board.
Oct 31, 2015 | Magic Audio Players & Recorders
Change language from german to english
If everything is coming up German, you will have to do this by following the icons. Look for the symbol or figure out what the "Control Pnel" is and open it. Now look for the icon that shows the shape of the world with a clock next to it, this is the "Regional and Language settings". At the top of that window are 4 tabs, the first tab is "formats", in the first drop down menu, scroll down and find "English-United States", select it and hit apply, bottom right button. Now the next tab to the right is "Location", there is one drop down menu, scroll down and select "United States". The next tab to the right is "Keyboards and Languages", the first button at the top is "Change Keyboards", click on this and when the next window opens, click on the first drop down menu and select "English (United States)-US, below that are listed keyboards, you will see the keyboard "US", highlight and remove all others listed in this area. Now click the next tab in this same window, it is the "Language Bar", check the third circle down and uncheck all the boxes under that, click apply and ok to clear this window. Now click on the last tab in the original window, this is the "Administrative" tab. Depending on what operating system you have these buttons maybe in different areas, try to look at the words and see if they are close to ours, anyway in this last tab, look for the button marked "location" or "system locale", whan you click on this another window comes up click ok to apply these settings to all users, it will then show another drop down menu, choose "English (United States)", hit enter, the machine will need to reboot to apply the settings. Now remember depending on the operating system these settings can vary, this instruction is for windows 7, vista is close but with a few variances.
Make sure also to click on the time in the right lower task bar and make sure the time zone and time are correct, there are a lot of computers that were placed in service with German languages that also have Luxemburg as the time zone.
Jul 27, 2010 | Toshiba Satellite A10-S169 Notebook
Coin completely jammed in vertical coin drop mechanism
unplug the machine,open the top of the coin op i use a stubby 5/16 nut driver,you have to remove the rod and it's a 5/16 inch rod,turn it counter clockwise to remove,this rod holds the unit in place,when you have the rod out then you can grab the front where you put the money in and lift it up and out,it sits in a couple of slotted holes
Nov 11, 2017 | Maytag MAT12CS Top Load Washer
When placing a call on HTC diamond tomtom 7 opens
check the directory where is tomtom installed. it should be on main directory on memocard.
Aug 20, 2009 | HTC Touch HD Smartphone
Brew unit wont go back in in seaco incanto
There is a flag on the back side of the brew unit. Below the flag are 2 plastic bars that the flag slides in. Push in between the 2 bars and see if the flag will drop. If it does holding the brew unit with your right hand, take your left hand and place it on the bottom left side of the brew unit, then with 2 fingers reach up inside the bottom and grab the bar in the center and squeeze the bar to the left. This will bring the cylinder back into position and align the 2 triangles on the front of the brew unit. Once they are aligned push the lever to the right to lock up the brew unit. Leave the brew unit out, but everything else in place, then turn the machine on. Once
the machine is settled open the door, remove the drip tray and then insert the brew unit, drip tray and close the door.
Apr 26, 2009 | Saeco Incanto Classic Espresso Machine
I am getting Call Service 7410:00 32266 on FS-3900DN Kyocera Laser Printer.
You have pulled the drum unit out of position possably after changing the waist toner ? Open the back cover, open the frunt cover and remove the developer unit, the full unit not just the toner, open the side cover where the waist toner bottle is and push the drum unit back into place until it clicks, put the dev unit back in place and close everything reboot the machine
Apr 18, 2009 | Kyocera FS-3900DN Laser Printer
Doc. Cover Open displayed
That usually means some sensor giving you trouble.
This is what brother recomends:
How do I clear the message Cover Open or Please Close Cover from the display?
The message Cover Open or Pls Close Cover may appear if the front cover
for the drum was not closed securely. Verify the cover is closed
securely by pressing the cover release button located in the front of
the unit below the Output Tray Support Flap and open the front cover.
Close the cover until it clicks into place.
If the message continues to appear on the display verify the drum and
toner assembly is installed correctly by following the steps listed
below:
1. Press the cover release button located in the front of the unit and
2. Remove the drum unit and toner cartridge from the unit by lifting it
up and out. Place it on a drop cloth or disposable paper to avoid
scattering toner.
3. Hold down the blue lock lever located on the right side of the drum
and lift the toner cartridge out of the drum unit.
4. Reinstall the toner cartridge into the drum unit by inserting it in
the drum until it clicks into place
5. Reinstall the drum unit into the unit. Make sure it is securely in
place.
6. Close the cover until it clicks into place
If that doesn't fix it, I guess you will have to talk to their support people.
Dec 15, 2008 | Brother MFC-8840D All-In-One Laser Printer
Dropped the system everything working but will allow me to go to the map screen
Did you try to reset the unit? Place you thumbnail in the groove located under the Garmin logo on the face plate. Gently pull off the face plate. Press the reset button. Turn the unit back on and see if it works - Of course replace the face plate carefully. Good luck! Dr. Know
Dec 20, 2007 | Garmin StreetPilot C330 GPS Receiver
My canon pixma mp500 it was working great until one day my boyfriend turn on the printer and its saying error 5100 and i menu but it wont work non of the buttons work i opened but everything seeings ok i...
5100 error will occur if the film strips has a dirt or most common if theres a drop of water or blots of ink..film slit strips are located at the carriage unit.when you open the cover you can see it place horizontally at tha back of the carriage unit.. bye
Sep 27, 2007 | Canon Pixma MP500 All-In-One InkJet...
Vertex radio vx 10
Maybe with the drop the radio speake is out of place, did try to open the radio and find if the speaker is in its correct place? The speaker uses a spring connector and this can be out of place. Good luck
Jun 22, 2007 | Vertex Yaesu Radio FTH2009, FTH7009...
Toshiba DVR620 DVD/VHS Recorder Black Logo
50 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
JohnLong
Blake Whiteside
Level 1 Expert
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
